car clicks when starting
Old Jun 14, 2005 | 03:12 PM
95integrags-r's Avatar
Default car clicks when starting
when I start the car it clicks repeatedly and the inside lights (dash lights, boost guage, and hondata shift light) flash as well with the clicks. I was curious what the problem might be... the things I thought might be worng are maybe the alarm was disarmed when it was in the shop and now it still is and wont let the car start...(the alarm doesnt sound when I click the beeper(though it still unlocks the doors). i had a resistor box wired up, but it was taken off now because I put my stock injectors back in. I thought that if the wires are possibly touching it might cause this. they are all taped with electrical tape, and then taped together, but im pretty sure none are touching. Im positive its not the battery because the lights all come on, and its not the started because that only clicks once, this clicks between 5 to 15 times while holding the key. thanks very much for any help you guys can offer me.
Old Jun 14, 2005 | 04:13 PM
SOHCmaster's Avatar
alt is bad or the diode inside is blown, will it still start if you jump it ? Im sure it will.
Old Jun 14, 2005 | 04:30 PM
Default Re: (PK SPEED)
if I jump it and let it run for a bit will it start again after that or do I need a completely new alt? thanks
Old Jun 14, 2005 | 08:07 PM
Default Re: (95integrags-r)
Old Jun 14, 2005 | 08:31 PM
SOHCmaster's Avatar
expensive ! Looking at 185 bucks after you get your 80 dollar core refund back
Old Jun 15, 2005 | 04:52 AM
dwnthehatch's Avatar
Your starter solenoid is bad.
Old Jun 15, 2005 | 11:00 AM
Default Re: (dwnthehatch)
starter solenoid?? when the starter needed to be replaced last year the sound was completely different. it just clicked once when I turned the key. when i turn the key now it clicks many times repeadedly while the key it turned and if my memory serves me correctly the clicks were of different tone.
Old Jun 20, 2005 | 10:32 AM
Old Jun 20, 2005 | 11:13 AM
Evil-EK's Avatar
how about a little diagnostics before you go buying new parts. I have had the same problem before. Check to make sure all the grounds are tight. The bracket that bolts to the tranny that in turn the ground bolts too may be loose. My car did the same thing when my gound was loose. Check all the fuses under the dash. There is one for the charging system. What year is the car? In 1997 the civic had a recall on alt/o2 wiring. Check before you buy parts.
Old Jun 20, 2005 | 09:44 PM
Default Re: (BigBlockH22atch)
i have 95 gs-r like the user name. I will check them in the morning and see where that gets me. thanks.
Ryan Edwards
Aug 6, 2015 12:39 PM
HondamanXxX
11
Aug 6, 2007 04:21 PM
1bar
Audio / Security / Video
May 18, 2005 04:36 PM
mariouch
Oct 29, 2003 07:34 PM
mariouch
Oct 28, 2003 06:51 AM
