Rev Limiter & Code 16
Old Jun 14, 2005 | 02:06 PM
Corporation's Avatar
Economic Upturn, WUT
From: Alittle Placed Called None of Your Damn Business.
Default Rev Limiter & Code 16
Ok me and a buddy put a d16z6 into a 91 Si. We have figured out all of the cel problems except 16 and with this we have the rev limiter at 3500 RPM. I was wondering if anyone had problems with this or experience with this same problem?
Thanks in advance.
Old Jun 14, 2005 | 03:08 PM
Mach69's Avatar
Default Re: Rev Limiter & Code 16 (ahrpr)
I just had this happen to me. The problem with mine was a main relay, code 16 is a symptom of a main relay failure is imminent. Hopefully, that will be your problem. Also, check to see if all your injector plugs are on the injectors. May sound stupid, but that could be the problem.
Also, I noticed that you put a z6 into your 91 si, you might have done a mistake with the resistor box:
obd-1 injectors: No resistor box
obd-0 injectors: Resistor box is needed
Here is what the manual says to do:
Page 1: http://www.we-todd-did-racing....3D%3D
Page 2: http://www.we-todd-did-racing....3D%3D
Page 3: http://www.we-todd-did-racing....3D%3D
Page 4: http://www.we-todd-did-racing....3D%3D
Page 5: http://www.we-todd-did-racing....3D%3D
Old Jun 14, 2005 | 03:14 PM
solareclipseauto's Avatar
Default Re: Rev Limiter & Code 16 (Mach69)
yeah check the fuel injectors
Old Jun 14, 2005 | 03:46 PM
Default Re: Rev Limiter & Code 16 (solareclipseauto)
well we didn't need to use the resistor box because they are odb1 we just soddered all of the wires together like mr. carpenters write up. I will check the main relay. And all of the ionjectors are firing. We will try tonight though.
Old Jun 14, 2005 | 04:02 PM
Mach69's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ahrpr &raquo;</TD></TR><TR><TD CLASS="quote"> And all of the ionjectors are firing.</TD></TR></TABLE>
If you know the injectors are good it can only be a few things because the injectors aren't getting power. THere is an open in the wire somewhere, or ur main relay is done.
Old Jun 14, 2005 | 04:14 PM
if my main relay is done will the car still start and drive like normal?
Old Jun 14, 2005 | 04:18 PM
Mach69's Avatar
Once you get it started it will drive like normal, but if the main relay is bad, it will either just crank and crank and crank, or it will just click when you go to start it. Mine did both.
Old Jun 14, 2005 | 04:21 PM
wel the funny thing is .. It starts just fine. It runs just fine too. We can drive it around the block and all for the most part. We are just throwing cel 16 .. its really wierd.
Old Jun 14, 2005 | 04:25 PM
also when we drive there is a tapping noise. Its not a rod knock .. im thinking it could be a valve tap because we had to replace the timing belt because it broke in the motor when he had it in his EG. Also there is no exhaust from the cat back. It sounds like a piece of **** lol.
Old Jun 14, 2005 | 05:01 PM
bump really need help going on a long trip in acouple days.
Old Jun 14, 2005 | 09:54 PM
bumpage for answers
crxsi814
Jan 6, 2011 07:01 PM
turbo-2nr
Jan 22, 2009 08:10 PM
juanchoenuncrx
11
Apr 4, 2008 07:38 AM
92_VX_EG
Nov 15, 2006 02:14 PM
Turbo_Mike
Jul 25, 2005 04:59 PM
