B16 Idle problem.
Old Jun 14, 2005 | 02:46 AM
supaman111's Avatar
Default B16 Idle problem.
hi, i have a idle problem which only occurs when the car is cold, when is warms up it is ok. I took the TB off and cleaned it out, re-set throttle cable, but still have a problem????
any ideas on what it can be.
sam
Old Jun 14, 2005 | 12:43 PM
timisyourfriend's Avatar
Default Re: B16 Idle problem. (supaman111)
what is the "problem"? is it idling at 9000rpm? is it bogging from 200-3000rpm? be more specific if you want someone to help.
Old Jun 14, 2005 | 12:59 PM
supaman111's Avatar
Default Re: B16 Idle problem. (JZPerformance)
Drops to about 100rpm and then rises to 1200rpm, it fluctuates around this area until it gets warm then it stops and idles normally???
sam
Old Jun 14, 2005 | 01:05 PM
handa's Avatar
I remember my b16 used to do this...then I bought a new radiator and it stopped.
You might have a radiator fluids (air pockets) leak in the system or FITV needs adjusting.
Try redoing your radiator fluid and adjusting the FITV first. If that doesn't work, check out this guide: http://jdmcity.com/forum/viewtopic.php?t=95
Old Jun 14, 2005 | 01:37 PM
supaman111's Avatar
Default Re: B16 Idle problem. (handa)
i recently changed my radiator for a new one same oem replacement, could this cause a prob i did it diy, and fluid is topped up? could it be a sensor?
Old Jun 14, 2005 | 01:38 PM
supaman111's Avatar
what is FITV?
Old Jun 14, 2005 | 01:48 PM
handa's Avatar
https://honda-tech.com/zerothread?id=699787
i did this on the same day of the radiator change, maybe this was the issue...not the radiator.
Old Jun 14, 2005 | 01:52 PM
jdmferio1320's Avatar
ITS YOUR IDLE AIR CONTROL VALVE. CHANGE THAT AND YOU'LL BE GOOD TO GO
Old Jun 14, 2005 | 02:09 PM
supaman111's Avatar
dont think i have one of those FITV things, will check it 2mrw just to make sure.
mine is obd1
Skyhigh07
Jan 15, 2009 11:48 AM
rdeezy78
Dec 22, 2006 04:51 PM
variable
Aug 18, 2006 05:03 PM
jseames
Aug 22, 2003 12:38 PM
TrevorHiroshima
Jul 24, 2003 10:24 PM
