B16 Idle problem.
B16 Idle problem.
hi, i have a idle problem which only occurs when the car is cold, when is warms up it is ok. I took the TB off and cleaned it out, re-set throttle cable, but still have a problem????
any ideas on what it can be.
sam
sam
Re: B16 Idle problem. (supaman111)
what is the "problem"? is it idling at 9000rpm? is it bogging from 200-3000rpm? be more specific if you want someone to help.
Re: B16 Idle problem. (JZPerformance)
Drops to about 100rpm and then rises to 1200rpm, it fluctuates around this area until it gets warm then it stops and idles normally???
sam
sam
I remember my b16 used to do this...then I bought a new radiator and it stopped.
You might have a radiator fluids (air pockets) leak in the system or FITV needs adjusting.
Try redoing your radiator fluid and adjusting the FITV first. If that doesn't work, check out this guide: http://jdmcity.com/forum/viewtopic.php?t=95
Re: B16 Idle problem. (handa)
i recently changed my radiator for a new one same oem replacement, could this cause a prob i did it diy, and fluid is topped up? could it be a sensor?
https://honda-tech.com/zerothread?id=699787
i did this on the same day of the radiator change, maybe this was the issue...not the radiator.
Skyhigh07
01-15-2009 11:48 AM
