dissappointing dyno day
Old Jun 13, 2005 | 07:26 PM
Suck my DX's Avatar
Default dissappointing dyno day
well i got a 1st gen b16/y1 tranny
3 inch short ram
maxbore 64 to 62 mm taper TB
AEBS IM
STR fuel rail
B&M FPR
full supertech valvetrain
aem cam gears
sk2s2 cams
dc-4-2-1
si catback
stock block
vafc
now i took it to get tuned on the dyno today and it seems that im way overcaming...i was getting 144 whp before the cams were installed...now im making 127 whp and 89 lb/ft torque....boy does this suck...well im looking to get ctr ot itr cams now as they tend to work best for my application i still cant believe i lost 17 peak whp...and torque is just as bad...oh well.. for me
Old Jun 13, 2005 | 07:38 PM
drdisco69's Avatar
Default Re: dissappointing dyno day (Suck my DX)
Yeah, those cams are huge for that engine. Post a scan?
Old Jun 13, 2005 | 07:40 PM
Kendall's Avatar
Your other option would be to invest in some very serious headwork, a damn good header/exhaust, and perhaps a thinner headgasket.
Flow > Compression
Old Jun 13, 2005 | 08:15 PM
Suck my DX's Avatar
Default Re: (Kendall)
yeah but that is still only going to yield top end power...this is my daily driver and i would definitely like a more streetable cam...
Old Jun 14, 2005 | 01:28 AM
hybridmiklo's Avatar
Did you tune the motor or just dyno it? Cause I had a 1st gen b16 with a very similar setup and at first it took a **** on the dyno. But after playing with the fuel and cam timing i put out 173 on church's dyno.
If it's not tuned and you just dynoed it the motor probably runs like crap and when vtec hit it just fell flat on its face.
Old Jun 14, 2005 | 06:57 AM
Suck my DX's Avatar
Default Re: dissappointing dyno day (hybridmiklo)
yeah bro i had the guy tune it on the dyno...he said that he wasnt gonna touch my cams because it wouldnt make a difference at this point..i think he was just lazy and didnt wanna take the valve cover off...why would they make adjustable cam gears if they dont do anything im just kinda mad cuz everyone tells me that this guy is a good tuner and he made less power than my motolr was makin before....i mean i know that the cams are big in this motor but it shouldnt be droppin power like that..**** i gotta go to work ..peace!
Old Jun 14, 2005 | 12:15 PM
Phatch99's Avatar
it can only get better.... go with a different tuner.
Old Jun 14, 2005 | 02:28 PM
Default Re: dissappointing dyno day (Phatch99)
Yeah, I would go with a different tuner. You have to play with the cam gears to get the most power out. Also, when you put the cams in did your timing suddenly retard itself? Something very similar happened to a friend of mine when he put in sk2st2 cams. The motor went into limp mode and when vtec engaged it sounded like his engine was going to blow up.
Old Jun 14, 2005 | 03:33 PM
Suck my DX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hybridmiklo &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, I would go with a different tuner. You have to play with the cam gears to get the most power out. Also, when you put the cams in did your timing suddenly retard itself? Something very similar happened to a friend of mine when he put in sk2st2 cams. The motor went into limp mode and when vtec engaged it sounded like his engine was going to blow up. </TD></TR></TABLE>
yeah i definetely wanna go to a different guy...but im not ecstatic about having to shell out another hundred bucks or more...yeah the timing was way screwy...we fixed it but it didnt seem to do much...the guy was kinda a dick though so i doubt that i will be going back to him...
Teamdiesel
32
Dec 23, 2009 05:36 AM
Suck my DX
76
Jun 19, 2005 07:23 AM
B18C2_sedan
Sep 11, 2003 03:22 PM
advanracing62
Feb 28, 2003 06:01 AM
acatak
Jul 13, 2002 02:19 PM
