How bad is it when oil goes where it shouldn't?
Old Jun 13, 2005 | 03:18 PM
D16Z6racing's Avatar
Default How bad is it when oil goes where it shouldn't?
<U>My Day...</U>
I drive to work...car running fine. I go on lunch...car won't start.
<U>The Problem...</U>
Turns over just fine, just no spark. I check connections of wires to distributor, fine. I check wires to plugs, gotta problem. 3 of 4 gaskets went bad, now I have oil inside my plug wires and covering my plugs.
<U>The Fix...</U>
I soak up what oil I can before removing the spark plugs. Couldn't get much out though. Replaced; spark plugs, spark plug wires, valve cover gaskets, 4 gaskets between valve cover and head protecting plugs, 4 gaskets on top on valve cover.
<U>Afterward...</U>
Car started just fine. I've only driven it twice since I replaced the parts. Driving it as little as possible at this moment.
<U>My question...</U>
Some oil did get through when the spark plugs were removed, how much I don't know. Should I be prepared for something else to got wrong relating to this or will that amount of oil just burn and not be a concern?
...this was on my 90 Accord EX.
Old Jun 13, 2005 | 03:48 PM
deserthonda's Avatar
it will burn ,,, do not worry about it
Old Jun 13, 2005 | 05:19 PM
SPEED FoRCE's Avatar
Default Re: (deserthonda)
you'll be fine, good job on fixing the problem before it escalated, most people just say '**** it' heh.
Old Jun 13, 2005 | 05:49 PM
Default Re: (SPEED FoRCE)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SPEED FoRCE &raquo;</TD></TR><TR><TD CLASS="quote">you'll be fine, good job on fixing the problem before it escalated, most people just say '**** it' heh.</TD></TR></TABLE>
Thought about that.
Was thinking a F22B swap (94-97 Accord EX...SOHC VTEC). But $75 in parts and 1 hour of my time was way cheaper. And continues my 261k+ on this car.
To avoid this in my other Accord I'm doing some easy maintance on it tomarrow as-well. Better to stay ahead.
Old Jun 13, 2005 | 09:01 PM
90AccordTx's Avatar
Default Re: (D16Z6racing)
So u mean to tell me if i have oil in my spark plugs location, thats bad..well i think two of spark plugs has oil on them..but i have no problem startin my car or runnin
Old Jun 13, 2005 | 09:13 PM
90accorddx's Avatar
Default Re: (90AccordTx)
I said **** it until one day i stuck a valve out on the highway
but my car was also burning like four quarts of oil a week
Old Jun 15, 2005 | 12:54 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90AccordTx &raquo;</TD></TR><TR><TD CLASS="quote">So u mean to tell me if i have oil in my spark plugs location, thats bad..well i think two of spark plugs has oil on them..but i have no problem startin my car or runnin</TD></TR></TABLE>
Fix it now to save $ down the road. I have no idea how long my gaskets were bad and was leaking oil into my plugs. Just one day...1 plug was completely submersed in oil and spark wasn't happening.
You motor can last sooooooooooo long. Take care of it now. I just passed 262k on my way home from work tonight.
Old Jun 15, 2005 | 10:03 AM
honda_kid42's Avatar
it is sooo easy to fix and doesn't cost much at all...it is really worth replacing the gasket!!!
Old Jun 15, 2005 | 12:55 PM
SloCrxDx91's Avatar
my mom's altima had the same problem. no problems since........it added a lot more horsepower since I did that!
Old Jun 15, 2005 | 06:50 PM
91 VTEC akkord's Avatar
Young Skywalker, you will be fine.
pwrofdrm
Mar 29, 2023 06:50 AM
murrellington
Mar 21, 2016 05:11 PM
Takymoto
Feb 17, 2007 05:51 PM
TypeR15
Feb 28, 2004 09:46 PM
Mike17
Feb 11, 2004 02:31 PM
