Oil + spark plugs = problems Help
I'm a Jackass
So my car was sputtering today (00 si) removed the spark plug wires and in cyl. 1 and 3 there was oil, none in 2 and 4. Checked the spark plugs and they were corrodid to ****.. oem from 2000, never been changed and has 100k on the car.. Question is.. Am I fucked here.. whats up with the oil in there??~
I'm a Jackass
Re: (Eran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allricedout »</TD></TR><TR><TD CLASS="quote">ask the parts shop for *rubber o ring gaskets under the valve cover* then get new wires, chances are that u were having a misfire.</TD></TR></TABLE>
there was a good amount in the chamber i guess you'd call it.. it was in the cylinder portion above the spark plug
I'm a Jackass
Re: (Takymoto)
I got new wires and spark plugs started the car and it was idling a little higher than normal and some smoke was coming outta the engine.. I'm guess it was burning off the excess oil
HT White Ops
Re: (Takymoto)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takymoto »</TD></TR><TR><TD CLASS="quote">cool.. ill replace the o rings tomorrow hopefully that helps</TD></TR></TABLE>
Urea grease, needle-nose pliers, flathead, and a mallet .... have fun
D16Z6racing
06-15-2005 06:50 PM
