Bad motor mount - ES inserts?
Old Jun 13, 2005 | 09:02 AM
Tim.'s Avatar
Default Bad motor mount - ES inserts?
I have searched and found a lot of information, but it is all contradicting and misleading info. I need some good solid info before i waste all of my money.
Here's the problem. The shitty drivers side upper motor mount (yes, the one next to the timing belt and between the tire and headlight - not the torque mount) is torn and out of place.
My mount doesn't look like the other ones i have seen (the big shiny silver ones) so i don't know if that could be a problem?
I want to get the Energy Suspension inserts for obvious reasons, it's a lot cheaper, and if it can rejuvenate the torn stock mount and make it even better than stock. why not?
Another thing that i saw that was misleading... are the ES inserts just for the torque mounts? in this case i would have to get a whole new mount. there are a couple different sets on ebay, that are totally different looking, is one set for the motor mounts and one set torque mounts?
http://cgi.ebay.com/ebaymotors...33583
http://cgi.ebay.com/ebaymotors...50454
here are some pics to help out. and is mine torn too bad? should a get a whole new mount?
Torn. And as you can see the brackets holding the bushing are misaligned.
All help is appreciated. Hopefully this will clear things up for me and all the others that have the same problem.
Old Jun 13, 2005 | 09:54 AM
vtecb20coupe's Avatar
B A N N E D
Default Re: Bad motor mount - ES inserts? (spoon0313)
by the pics you've provided, it appears to me that you have a 99-00 civic. that mount is hydraulic, which unfortunately, is more expensive to replace. and i believe that the only mounts that es makes are the rear and two lower torque mounts.
Old Jun 13, 2005 | 10:21 AM
Tim.'s Avatar
yea its a 2000. looks like i'll be buying a new mount.
anyone else know if the inserts are just for the torque mounts or not?
Old Jun 13, 2005 | 10:36 AM
EE_Chris's Avatar
Default Re: (spoon0313)
Prothane makes an insert for that mount (upper driverside) - I have it on my 99 hatch.
Old Jun 13, 2005 | 12:11 PM
GetawayInMoscow's Avatar
Default Re: (EE_Chris)
Prothane inserts replace that mount. I heard it's a huge PITA to replace and then also they are so stiff your car will vibrate like a **** afterwards.
Old Jun 13, 2005 | 01:06 PM
EE_Chris's Avatar
Default Re: (GetawayInMoscow)
I'm not sure what you're referring to, but its absolutely not a PITA - it took all of 5 minutes. It took longer to let the PB Blaster settle on the nuts than it was to install them.
They just slip in under the metal part.
Old Jun 13, 2005 | 01:09 PM
Tim.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EE_Chris &raquo;</TD></TR><TR><TD CLASS="quote">Prothane makes an insert for that mount (upper driverside) - I have it on my 99 hatch.</TD></TR></TABLE>
cool. how do you like it?
where did you get it from and how much $$?
Old Jun 13, 2005 | 01:22 PM
EE_Chris's Avatar
I think the site was something like suspensionrestorationparts.com - but you can get just as good, if not better prices off of e-bay or the vendors section. I believe I paid about $30 for 3 inserts - the rear mount and the passenger and driver side upper mounts.
I only installed them as a means to stiffen up my worn out stock mounts that had about 200k on them but if I could do it again, I'd just go with fresh stock mounts. The interior buzz at idle is fine for me but not for most passengers.
Old Jun 13, 2005 | 01:24 PM
igo4bmx's Avatar
anyone know where you can get those wire ties that cme with the inserts?
i need a couple of them
Old Jun 13, 2005 | 01:34 PM
.:Swig:.'s Avatar
Default Re: (igo4bmx)
bump
Old Jun 13, 2005 | 03:25 PM
Tim.'s Avatar
up top
Old Jun 14, 2005 | 07:33 AM
Tim.'s Avatar
up
Old Jun 14, 2005 | 07:45 AM
SlepT ej6's Avatar
I have the same exact problem, i was thinking about going with a completely new hasport driver side upper mount but i figured for the price i can buy almost 3 new ones from the dealer...... so im going with an OEM replacement now that i have the mount inserts on my torque mounts and rear mount, its stiff enuff!
Old Jun 14, 2005 | 07:52 AM
Tim.'s Avatar
there is no chance that i will go with OEM, they are obviously pieces of ****..
Old Jun 14, 2005 | 08:28 AM
EE_Chris's Avatar
HASport does make replacements for our chassis. They are especially useful when performing a swap but they cost a lot more than OEM stuff, so I didn't bother recommending it.
Jimfab makes some too, so that's another option....
Old Jun 14, 2005 | 08:55 AM
SlepT ej6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoon0313 &raquo;</TD></TR><TR><TD CLASS="quote">there is no chance that i will go with OEM, they are obviously pieces of ****.. </TD></TR></TABLE>
Well my car is close to 10 years old, so if by getting a brand new on i think my chances are greate rto it not brekaing anytime soon but truthfully who knows how it will hold it, if i see that it not holding up due to the power im putting down always room to upgrade, but OEM can definately but a good reliable quick fix!
Old Jun 14, 2005 | 09:42 AM
Tim.'s Avatar
true ^^^
Old Jun 14, 2005 | 10:48 AM
dwnthehatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by igo4bmx &raquo;</TD></TR><TR><TD CLASS="quote">anyone know where you can get those wire ties that cme with the inserts?
i need a couple of them</TD></TR></TABLE>
Go to autozone and get a transmission cooler mount kit. It will run you $6
Old Jun 14, 2005 | 10:54 AM
igo4bmx's Avatar
Default Re: (dwnthehatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dwnthehatch &raquo;</TD></TR><TR><TD CLASS="quote">Go to autozone and get a transmission cooler mount kit. It will run you $6</TD></TR></TABLE>
awesome!
nebulight
Oct 27, 2006 08:04 AM
SOHC_Brian
Aug 11, 2004 11:30 AM
Nextelbuddy
24
Apr 14, 2004 04:55 PM
Brewer
Mar 23, 2004 07:30 PM
inzaneN1
Feb 26, 2004 12:23 AM
