New into the import business
Old Jun 12, 2005 | 06:07 PM
ITRracer16's Avatar
Default New into the import bussiness???????????
i just want to know how all you guys know how to tell apart ITR's engines from GSR's and all the other Vtec engines? i dont know how to tell them apart? could you help me out....
thanks
Old Jun 12, 2005 | 06:16 PM
PY 01-0972's Avatar
before everybody rips u a new one and tells u to use the search button i will say... the engine stamp on the block is b18c5 it has
a red valve cover it has a single plane intake
manifold if its in a car ITR engines come with
an limited slip differential witch is stamped on the trans with a big bold LSD. if the engine is out of a car and you can pull the oil pan off you would notice some little aluminum straw type pieces that squirt oil onto the pistons to help burn in at high rpms. if the head is off i believe the pistons have a P73 stamp on them. I think thats the most obvious. well
it also has a better stock header than say
a GSR or Si.
Old Jun 12, 2005 | 07:16 PM
d.n.d.'s Avatar
Default Re: (PY 01-0972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PY 01-0972 &raquo;</TD></TR><TR><TD CLASS="quote">before everybody rips u a new one and tells u to use the search button i will say... the engine stamp on the block is b18c5 it has
a GSR or Si.</TD></TR></TABLE>
wee there r still good ppl out there ITRracer16 try to watch what u ask eh? not everyone is as forgiving......
Old Jun 12, 2005 | 07:26 PM
ZygSpeed's Avatar
Default Re: New into the import bussiness??????????? (ITRracer16)
There's a lot of good info in this old link ...
http://autopedia.com/Acura/97_IntR.html
Old Jun 13, 2005 | 04:08 AM
ITRracer16's Avatar
Default Re: New into the import bussiness??????????? (zygspeed)
well thanks for your help guys and i'll try to do some more research and ask better questions before some1 starts talking **** to me.....
Old Jun 13, 2005 | 04:31 AM
Bbasso's Avatar
https://honda-tech.com/zerothread?id=163515&page=1 Found in the FAQs ...
Old Jun 14, 2005 | 04:30 PM
Hooch'n's Avatar
engine codes......mmmm
Old Jun 14, 2005 | 06:12 PM
MugenHonda's Avatar
From: With my POS D15B2, Whereever whenever, United States
lol wrong forum
Old Jun 14, 2005 | 08:28 PM
uNF$@#!'s Avatar
you should not be importing if you dont even know this.
Old Jun 15, 2005 | 08:46 AM
ITRracer16's Avatar
Default Re: New into the import bussiness??????????? (255.255.255.255)
well i knew how to tell Vtec engines apart by the code but i didn't know if people have another way of telling them apart.....
thanks guys
S@nt0s
Honda S2000
12
Jan 4, 2009 08:14 AM
BlackCD5
Aug 6, 2007 05:37 PM
juniestyle
May 23, 2007 02:32 PM
NinjaTech
Mar 15, 2005 02:47 PM
Civicdrgrcr
Dec 25, 2002 08:06 AM
