Dented Header Hurt Performance??
Old Jun 12, 2005 | 01:18 PM
{Powered by VIII}'s Avatar
Default Dented Header Hurt Performance??
i wanted to see what you guys think about this pretty good size dent i have in my comptech long tube header. i bought it like this so it wasn't my fault, but i want to see if it's big enough to where it's gonna hurt the performance and should do something about and if it is what can i do??
Thanks. Alex.
Old Jun 12, 2005 | 01:40 PM
uNF$@#!'s Avatar
Default Re: Dented Header Hurt Performance?? ({Powered by R})
Old Jun 12, 2005 | 01:41 PM
baonest's Avatar
cut it out, and patch it.
Old Jun 12, 2005 | 01:45 PM
.water's Avatar
Default Re: (baonest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest &raquo;</TD></TR><TR><TD CLASS="quote">cut it out, and patch it. </TD></TR></TABLE>
what he said..and i dont think it will hurt performance. since its bigger than stock anyways.
Old Jun 12, 2005 | 02:24 PM
Padawan's Avatar
Darth ModerVader
I would definitely suggest repairing the damage, especially on a high-end header such as that. Willard performed a similar repair a while back on a JDM ITR 4-1. Here's a link to his thread: https://honda-tech.com/zerothread?id=800124
Old Jun 12, 2005 | 02:48 PM
Accord95Lxxx's Avatar
i had a similar problem with my civic and i didnt notice anything bad, didnt seem slower, it was a DC sportz
Old Jun 12, 2005 | 03:27 PM
if i cut the dent out and weld in a new piece, isn't that going to weaken that area??
Old Jun 12, 2005 | 03:40 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by {Powered by R} &raquo;</TD></TR><TR><TD CLASS="quote">if i cut the dent out and weld in a new piece, isn't that going to weaken that area??</TD></TR></TABLE>
Not if the welding is done properly. You shouldn't even need a new piece. As seen in Warren's thread, you should be able to reshape the cutout piece and then weld it back in.
Old Jun 12, 2005 | 09:49 PM
fullraceacura's Avatar
Default Re: Dented Header Hurt Performance?? (Padawan)
you should be able to pull that dent out if you dont want ot cut it out and reweld it
my mugen header is dented pretty dam good but i cant tell if its affecting performance, its still the same as wide on the sides its just flat on the bottom though...
mugen
Old Jun 12, 2005 | 10:01 PM
Bbasso's Avatar
It will restrict the exhaust flow out of one cyl and cause it to run hotter and possibly leaner or richer. I would reapir that or replace it asap.
Old Jun 12, 2005 | 10:38 PM
niterida's Avatar
shouldn't hurt performance that much.
I personally wouldn't worry about it.
having that small of area taken out of the cross- section is just like having an o2 sensor there.
minimal effect on overall flow of an exhuast system.
Old Jun 13, 2005 | 05:19 PM
itr1244's Avatar
Default Re: Dented Header Hurt Performance?? (niterida)
are thoes DC's?
i had dc and it looked just like that
Old Jun 13, 2005 | 05:27 PM
JDMSpoonType-R's Avatar
Default Re: Dented Header Hurt Performance?? (itr1244)
Couldn't you just PDR it, you know, pop it out with the same tools they use to pop dents out? :Shrug: Just a thought.
Old Jun 13, 2005 | 05:43 PM
Default Re: Dented Header Hurt Performance?? (JDMSpoonType-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMSpoonType-R &raquo;</TD></TR><TR><TD CLASS="quote">Couldn't you just PDR it, you know, pop it out with the same tools they use to pop dents out? :Shrug: Just a thought. </TD></TR></TABLE>
PDR it??
Old Jun 13, 2005 | 05:53 PM
Paintless Dent Repair.........
Old Jun 15, 2005 | 09:07 AM
mehdiR's Avatar
I would't carry the deted header burden on my shoulder.
mine was worse than this , and I cut two exact pices and we TIG welded it on the opwen patches.
I ll send u some pics of it later
cheers
StreetEG
Nov 28, 2006 12:28 PM
neo_
63
Oct 20, 2006 04:24 AM
{Powered by VIII}
Jun 12, 2005 08:12 PM
civic91
Sep 9, 2003 02:00 PM
AllMotorMark
19
Jun 15, 2003 03:35 PM
