rev red line
Old Feb 10, 2002 | 05:35 PM
Ignitecivic's Avatar
Default rev red line
i know this foo with his crx Dx motor. and they said that when they took out the ac,ac belt, and the power steering, the car can rev max up to 8000 rpm. is that **** true. or doing that really works.
Old Feb 10, 2002 | 05:37 PM
.nate's Avatar
Default Re: rev red line (Ignitecivic)
bullshite. plain and simple. removing that **** doesnt raise your rev limit.
Old Feb 10, 2002 | 06:32 PM
deepnite's Avatar
reprogram the ecu and raise the rpm level to blow
Old Feb 11, 2002 | 08:31 AM
Default Re: rev red line (deepnite)
i know that **** is a lie. u cant rev more if the ac is off. those foo were ssaying that ****. i dont believe it too.
Old Feb 11, 2002 | 08:48 AM
ekekek's Avatar
reving only deals mostly with the valvetrain. the valve springs are the main part because if they cant handle the speed of the cams, then you get valvefloat which ends up in broken or bent valves. the pistens get some dings and dents too im sure. 2 be able to rev that high, of coarse you need to raise the rev limiter.
KpaTyH
10
Feb 28, 2010 01:52 PM
04Sispeed
Apr 25, 2005 04:10 AM
JDM00SI
Sep 17, 2004 01:14 PM
HondaLife
14
Mar 8, 2003 12:33 PM
