rev red line
rev red line
i know this foo with his crx Dx motor. and they said that when they took out the ac,ac belt, and the power steering, the car can rev max up to 8000 rpm. is that **** true. or doing that really works.
Re: rev red line (deepnite)
i know that **** is a lie. u cant rev more if the ac is off. those foo were ssaying that ****. i dont believe it too.
Re: rev red line (Ignitecivic)
reving only deals mostly with the valvetrain. the valve springs are the main part because if they cant handle the speed of the cams, then you get valvefloat which ends up in broken or bent valves. the pistens get some dings and dents too im sure. 2 be able to rev that high, of coarse you need to raise the rev limiter.
