jig making?
Old Jun 12, 2005 | 09:44 AM
efHondefender's Avatar
Default jig making?
What's the most straight forward way of making a good jig for turbo manis and various exhaust set ups. Any helpfull responses will be greatly appreciated. Thanks.
Old Jun 12, 2005 | 04:24 PM
ExploitedRacing-HR's Avatar
Usually people will just make a jig for the collector and tack weld the piping as they go.. usually it works out better in the end like that.
Old Jun 13, 2005 | 09:01 AM
Default Re: (ExploitedRacing)
I need to know the best way to make duplicate manifolds after I make the first.
Old Jun 13, 2005 | 09:31 AM
GeeGee's Avatar
Default Re: (efHondefender)
I don't know the answer to your question, but i'll tell you this. You wouldn't have any luck getting any info on a collect jig, let alone a whole manifold jig. In this tough competetive market, people like to keep thier ideas/jig a secret.
Old Jun 14, 2005 | 10:57 AM
cstay's Avatar
Default Re: (Krabbypro)
i will be attempting to make an entire manifold jig soon i made a verry simple collevtor jig just make the manifold then find a way to make it so every one after has the exact same demensions
Old Jun 14, 2005 | 03:18 PM
Default Re: (cstay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cstay &raquo;</TD></TR><TR><TD CLASS="quote">i will be attempting to make an entire manifold jig soon i made a verry simple collevtor jig just make the manifold then find a way to make it so every one after has the exact same demensions
I understand that much. That is exactly what I want to do. I know what a jig does. I was just trying to get some info as to what the easiest and most commonly practiced way was. I understand that it is a competetive market as someone else stated. I would understand if nobody wants to help me out, but it is not going to deter me from doing this. I'll just have to find out the hard way through trial and error. I had a few ideas and was basically curious as to if I was on the right track.
Old Jun 14, 2005 | 09:13 PM
LSiTurbo's Avatar
Easiest thing to do is get a spare cyl head or engine.... and find the turbo placement your looking for.... then simply make a bracket off the head or block(make it very sturdy) too which you can bolt a turbo flange.
BAM!
done!
wasnt that easy?
TigWiz
Welding / Fabrication
13
Nov 30, 2007 06:01 PM
turbo boost
Sep 28, 2006 06:03 AM
MugenFlaredCRX
May 26, 2005 12:08 AM
nebulight
Nov 13, 2004 01:44 PM
mugensport9
10
Sep 19, 2004 02:34 PM
