Clutch Pressure Problem....How Can I Check To See If It's The Master Cylinder?
Old Jun 12, 2005 | 04:40 AM
DRKSol's Avatar
Default Clutch Pressure Problem....How Can I Check To See If It's The Master Cylinder?
ok....its a92 cx with 93 dx motor and a ex tranny... i changed the clutch and flywheel and when we tried to bleed the clutch it had some pressure but not enough... you can build some pressure but then its just goes away... i chnaged the slave cylinder and i was wondering before i go buy a mc if there is a way to check it and make sure its bad or ok....oh yeah i dont know if this matters but with the cap on you can squeeze the small line and hear air (i think) but if the cap is off you cant...
Old Jun 12, 2005 | 05:29 AM
Mleach's Avatar
Default Re: Clutch Pressure Problem....How Can I Check To See If It's The Master Cylinder? (jh)
if the shaft of the master cylinder is wet, then youve got a problem.
Old Jun 12, 2005 | 05:31 AM
Chiovnidca's Avatar
Do you have all the air bled out of the system?
Old Jun 12, 2005 | 05:50 AM
DRKSol's Avatar
Default Re: Clutch Pressure Problem....How Can I Check To See If It's The Master Cylinder? (Chiovnidca)
i beleive i took all the air out... i bled it the normal way where someone pumps teh pedal 10 times and then open the bleeder..(like 11 times) and then putting a line on th end of the bleeder and the other in fluid..nothing seems to work...
what do you mean fluid on the shaft? could there be anything else?
Old Jun 12, 2005 | 11:07 AM
DRKSol's Avatar
i changed the master cylinder and it built up pressure and when i drove it it went back to no pressure????????
Old Jun 12, 2005 | 11:11 AM
Chiovnidca's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jh &raquo;</TD></TR><TR><TD CLASS="quote">i changed the master cylinder and it built up pressure and when i drove it it went back to no pressure????????</TD></TR></TABLE>
Make sure there are no leaks and try bleeding it again.
alvinoolivas
Sep 2, 2011 02:04 PM
iheartmy94eg
Jul 11, 2008 03:18 PM
matto2413
Sep 11, 2005 09:01 PM
matto2413
Jul 16, 2005 07:08 PM
5ltreater
May 2, 2005 06:32 PM
