What can i use from a Auto 94 EX in my 95 Civic DX hatch?
Old Jun 11, 2005 | 09:51 PM
vtec25's Avatar
Default What can i use from a Auto 94 EX in my 95 Civic DX hatch?
like if i want to use the engine can i use the harness or would it be easier to wire up everything with the DX harness?
Old Jun 11, 2005 | 09:58 PM
slotec's Avatar
Default Re: What can i use from a Auto 94 EX in my 95 Civic DX hatch? (vtec25)
use ur harness but jus wire in the vtec wires thru the firewall to the ecu. very simple.
Old Jun 11, 2005 | 10:52 PM
MiMiK's Avatar
you'd need a 5 speed vtec ecu too.
Old Jun 12, 2005 | 01:52 AM
speedfreek128's Avatar
Default Re: (MiMiK)
ecu doesnt have to b manual...can chip to manual and change specs
Old Jun 12, 2005 | 09:11 AM
EARLdaSQUIRREL's Avatar
official honda whore
just use the ex harness, will plug up perfectly, you wont have any problems at all
also jus have someone make your auto p28 into a manual one or trade someone, most chippers wouldnt mind having an auto one because they can use the auto parts from it
Old Jun 12, 2005 | 11:29 AM
sohcvtec1995's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec25 &raquo;</TD></TR><TR><TD CLASS="quote">like if i want to use the engine can i use the harness or would it be easier to wire up everything with the DX harness?
also you can use pretty much everything from the ex. Brakes, cluster, Brake booster, cruise control, and more. Why not just keep the ex and build that? it would be easier. all you would have to do is 5 speed swap, and a new ecu, or a chipped one.
Old Jun 14, 2005 | 06:32 AM
Default Re: What can i use from a Auto 94 EX in my 95 Civic DX hatch? (sohcvtec1995)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">
also you can use pretty much everything from the ex. Brakes, cluster, Brake booster, cruise control, and more. Why not just keep the ex and build that? it would be easier. all you would have to do is 5 speed swap, and a new ecu, or a chipped one.</TD></TR></TABLE>
imo id rather switch motors then going through a auto to 5 speed conversion
Joacnel
Aug 25, 2012 03:53 AM
delsolo95
Oct 14, 2011 05:53 PM
sacej2
Mar 7, 2008 02:59 AM
sleeping beauty
Jun 18, 2004 10:04 AM
b20vtecEK
May 3, 2004 11:12 PM
