front bumper screws,seized. best way to get out
Old Jun 11, 2005 | 05:12 PM
spoolnbyu's Avatar
Default front bumper screws,seized. best way to get out
sup guys,
my front bumper screws are seized,the ones that are under the hood. what is the best way to get them out? i tried all i can with a phillips screw driver and didnt come out. and they stripped,well,most of them. tried wd40 and still wont come out
Old Jun 11, 2005 | 05:45 PM
CL9WestCoastin's Avatar
Default Re: front bumper screws,seized. best way to get out (spoolnbyu)
vise grip will do the trick
Old Jun 11, 2005 | 06:02 PM
EG-SI(rII)'s Avatar
PB bolt loosener and visegrips, or find someone with snap on tools (if it's hex head bolts you're talking about)
Old Jun 11, 2005 | 06:33 PM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spoolnbyu &raquo;</TD></TR><TR><TD CLASS="quote">sup guys,
my front bumper screws are seized,the ones that are under the hood. what is the best way to get them out? i tried all i can with a phillips screw driver and didnt come out. and they stripped,well,most of them. tried wd40 and still wont come out</TD></TR></TABLE>
i assume you mean the 5/6 bolts that bolt the top of the bumper to the frame? i had one stuck too.. the best and easiest was to use a dremel and make a deep line across. then i took my flat head and hammer and wacked one end until it turned loose..
Old Jun 11, 2005 | 06:40 PM
sleeperHatch's Avatar
If you hadnt striped them out, you could have taken a hammer and given the screwdriver a firm tap while it was on the screw...most of the time that helps to get them to break loose!
Old Jun 11, 2005 | 06:51 PM
EK k kay's Avatar
Default Re: front bumper screws,seized. best way to get out (sleeperHatch)
Impact driver.
Old Jun 11, 2005 | 07:49 PM
HiProfile's Avatar
Default Re: front bumper screws,seized. best way to get out (chowmien)
I'm assuming they're the plastic ones between the headlights? I almost stripped one (was a bitch to the last thread). You really can't get any pb blaster on them because the washer below is rubber - you have to pour a few ounces on it at once (sits in a weird cavity, overspray/drips go around it). Slotting them with a dremil will work, unless you make the slot sides more curved than edgy. Best thing is to put all your weight on the end while turning it. Or get a newer civic - my friend's '00 was a cakewalk, she coulda got the bumper off herself.
Old Jun 12, 2005 | 07:39 PM
T4eg's Avatar
Default Re: front bumper screws,seized. best way to get out (loketran)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loketran &raquo;</TD></TR><TR><TD CLASS="quote">vise grip will do the trick</TD></TR></TABLE>
RedEG8
12
Dec 12, 2008 11:53 AM
rice a roni
15
Sep 9, 2004 12:57 PM
crashN2u
10
Jul 16, 2004 05:49 PM
anothersickhatch
Jun 19, 2004 11:04 PM
TwistedSI
Apr 6, 2003 05:34 PM
