why my DA integra cooling fan doesn't switch on??? anybody help.
Old Jun 11, 2005 | 06:58 AM
og asr's Avatar
Default why my DA integra cooling fan doesn't switch on??? anybody help.
Here's the situation....
Overheating problems are occuring with stop and go. I have narrowed it down to the cooling fan not coming on.
-- I unplugged the cooling fan and wired it directly to battery...so I know the FAN works...
Any suggestions as to testing other things?
I checked the fuses for cooling fan and cooling fan relay inside car fuse box...
I have heard that maybe the cooling fan relay is no good....Where is that located???
Also, is there a test for the cooling fan switch which in my case is located on the thermostat housing (like newer teg's)?
Please let me know guys.
Thanks.
Old Jun 11, 2005 | 07:06 AM
HoUTX98GSR's Avatar
Default Re: why my DA integra cooling fan doesn't switch on??? anybody help. (og asr)
thermo fan switch.. i think on a da its on the back of the block.. it could be that or the relay.
Old Jun 11, 2005 | 07:10 AM
og asr's Avatar
Default Re: why my DA integra cooling fan doesn't switch on??? anybody help. (HoUTX98GSR)
I modified my cooling fan switch to be on the thermostat.
Also, where is the cooling fan relay located????
Anybody?????
Old Jun 11, 2005 | 07:22 AM
97tegGS's Avatar
http://www.alldatapro.com/alld...37373
Old Jun 11, 2005 | 07:24 AM
97tegGS's Avatar
Old Jun 11, 2005 | 09:33 AM
og asr's Avatar
Default Re: (97tegGS)
Problem fixed....
Thanks for all your help...
It was a bad relay.......
Jumped the cooling fan switched with a jumper wire to test...and relay was not clicking.....
Took the relay off of my A/C..(which is now gone)....and she works again....
Old Jun 11, 2005 | 11:12 AM
HoUTX98GSR's Avatar
Default Re: (og asr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by og asr &raquo;</TD></TR><TR><TD CLASS="quote">
Took the relay off of my A/C..(which is now gone)....and she works again....</TD></TR></TABLE>
was going to tell you to do that (to test it)... good job.
Old Jul 3, 2005 | 07:14 PM
ev0luti0n's Avatar
I'm also having problems. Tried paperclip trick and it worked. Thing is car doesn't overheat ever. Could it be car just doesn't get hot enough for fan to turn on?
Old Jul 3, 2005 | 07:40 PM
cleanDA9's Avatar
i had the same problem take it to a honda shop and they can wire it to whenever the ignition is on. that's what i did on mine and it's been running fine since. it doesn't do anything but when it's cold it just takes longer to heat up. woop dee freakin doo.
Old Jul 3, 2005 | 08:51 PM
confewcious's Avatar
Default Re: why my DA integra cooling fan doesn't switch on??? anybody help. (Papa C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Papa C &raquo;</TD></TR><TR><TD CLASS="quote">i had the same problem take it to a honda shop and they can wire it to whenever the ignition is on. that's what i did on mine and it's been running fine since. it doesn't do anything but when it's cold it just takes longer to heat up. woop dee freakin doo.</TD></TR></TABLE>
the problem with that is when you're on the highway, there is no need for the fan to be on.
i like it working the right way, for the fan to come on when its suppose to. no mickey mouse for me.
Old Jul 4, 2005 | 12:33 AM
ev0luti0n's Avatar
i understand taht when highway it doesn't need to be on. but mines is never ever on. need to find out why. car never overheats either dunno what to do.
apexi_rsx
Jul 19, 2013 07:43 PM
19 crx 89
10
Aug 26, 2010 12:38 PM
xTomei
10
Jun 7, 2010 06:02 PM
littleblue
Oct 14, 2008 04:44 AM
Hybrid
May 18, 2002 12:52 PM
