why my DA integra cooling fan doesn't switch on??? anybody help.
Here's the situation....
Overheating problems are occuring with stop and go. I have narrowed it down to the cooling fan not coming on. -- I unplugged the cooling fan and wired it directly to battery...so I know the FAN works... Any suggestions as to testing other things? I checked the fuses for cooling fan and cooling fan relay inside car fuse box... I have heard that maybe the cooling fan relay is no good....Where is that located??? Also, is there a test for the cooling fan switch which in my case is located on the thermostat housing (like newer teg's)? Please let me know guys. Thanks. |
Re: why my DA integra cooling fan doesn't switch on??? anybody help. (og asr)
thermo fan switch.. i think on a da its on the back of the block.. it could be that or the relay.
Re: why my DA integra cooling fan doesn't switch on??? anybody help. (HoUTX98GSR)
I modified my cooling fan switch to be on the thermostat.
Also, where is the cooling fan relay located???? Anybody????? |
Re: (97tegGS)
Problem fixed....
Thanks for all your help... It was a bad relay....... Jumped the cooling fan switched with a jumper wire to test...and relay was not clicking..... Took the relay off of my A/C..(which is now gone)....and she works again.... |
Re: (og asr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by og asr »</TD></TR><TR><TD CLASS="quote">
Took the relay off of my A/C..(which is now gone)....and she works again....</TD></TR></TABLE> was going to tell you to do that (to test it)... good job. https://honda-tech.com/forums/images/smilies/emthup.gif |
I'm also having problems. Tried paperclip trick and it worked. Thing is car doesn't overheat ever. Could it be car just doesn't get hot enough for fan to turn on?
i had the same problem take it to a honda shop and they can wire it to whenever the ignition is on. that's what i did on mine and it's been running fine since. it doesn't do anything but when it's cold it just takes longer to heat up. woop dee freakin doo.
Re: why my DA integra cooling fan doesn't switch on??? anybody help. (Papa C)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Papa C »</TD></TR><TR><TD CLASS="quote">i had the same problem take it to a honda shop and they can wire it to whenever the ignition is on. that's what i did on mine and it's been running fine since. it doesn't do anything but when it's cold it just takes longer to heat up. woop dee freakin doo.</TD></TR></TABLE>
the problem with that is when you're on the highway, there is no need for the fan to be on. i like it working the right way, for the fan to come on when its suppose to. no mickey mouse for me. |
i understand taht when highway it doesn't need to be on. but mines is never ever on. need to find out why. car never overheats either dunno what to do.
