HOW to BAR yur new engine swap?
Old Jun 11, 2005 | 12:00 AM
ivtecboi's Avatar
Default HOW to BAR yur new engine swap?
hey i was wondering how do i BAR my car with with GSR motor in there? does any have any personal experience going through that stage? If so wat does it cost to do it? wat do u need to double check before u take it to the REF? Wat do they look for in particular? ..tahnks
Old Jun 11, 2005 | 01:22 AM
rasinhell's Avatar
Default Re: HOW to BAR yur new engine swap? (ivtecboi)
mmm... you would need a turbo kit.
Old Jun 11, 2005 | 01:51 AM
Luserkid's Avatar
Default Re: HOW to BAR yur new engine swap? (Plugg'd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Plugg’d &raquo;</TD></TR><TR><TD CLASS="quote">mmm... you would need a turbo kit. </TD></TR></TABLE>
Uhh no. You need to do alot of research though. Basically in a nut shell, make sure the motor is newer then your car and make sure it could pass smog. Cost 38.50 to take the test.
Old Jun 11, 2005 | 08:27 AM
AnDThEnWuT's Avatar
Default Re: HOW to BAR yur new engine swap? (Luserkid)
its simple, its pretty much like a regular smog check. just need the rite ecu, vacumm lines are routed correctly, and if you have a jdm obd1 b16 like i do, you would need to either tap a vacumm line into the intake manifold or get a usdm intake manifold. plain and simple, not as tough as people make it out to be.
Old Jun 11, 2005 | 08:29 AM
AnDThEnWuT's Avatar
Plugg'd i like your avatar, i have a picture of me and Trick Daddy giving the shocker!!!
Old Jun 11, 2005 | 08:58 AM
suspendedHatch's Avatar
Default Re: HOW to BAR yur new engine swap? (AnDThEnWuT)
The vacuum line to the IM is for the fuel canister, right? Is it acceptable to use a vacuum T from something like the FPR vacuum source?
Sometimes it's easier to get a smog legal aftermarket part than it is to get the OEM part. Exhaust manifold/downpipe is a good example. Unless you get a front clip, it's doubtful that part is going to make it across the pacific in good enough shape to use.
I have an OBD1 ZC motor in place of the non vtec D15. So far I haven't had to smog it but I doubt the smog shop will take a second look. Unfortunately I'm using my D15 exhaust mani...
Old Jun 11, 2005 | 10:14 AM
debo*'s Avatar
Default Re: HOW to BAR yur new engine swap? (suspendedHatch)
i just went to smog my gsr hatch, it has intake, header, and exhaust, i did the swap with some help from my dad, when i went to smog it, everything passed except my header, make sure your header is legal or you have the stock one on it, make sure it has the carb exempt tag on the header or they will fail you. i failed for that reason
Old Jun 11, 2005 | 11:02 AM
Del Sol SiR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivtecboi &raquo;</TD></TR><TR><TD CLASS="quote">hey i was wondering how do i BAR my car with with GSR motor in there? does any have any personal experience going through that stage? If so wat does it cost to do it? wat do u need to double check before u take it to the REF? Wat do they look for in particular? ..tahnks</TD></TR></TABLE>
You can make an appointment with the CA State Ref and ask them what you'll need. First decide if you need to be OBD1 or OBD2 on your set up.
So helpful???
Old Jun 11, 2005 | 08:09 PM
ivtecboi's Avatar
thanks for the reply....ill probably get my gsr swap...hopefully soon...cant wait to be legit...=D cop cant do **** now muahahaha...anyways thanks for the reply really helpful
Old Jun 11, 2005 | 08:10 PM
ivtecboi's Avatar
except for "plugg"...turbo= legit??hahaha all the racer out there is still wish upon that...=D maybe one day it will come true =D
Old Jun 11, 2005 | 10:38 PM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ivtecboi &raquo;</TD></TR><TR><TD CLASS="quote">except for "plugg"...turbo= legit??hahaha all the racer out there is still wish upon that...=D maybe one day it will come true =D
There called CARB legal kits. Greddy, Edlebroke, some others i think have smog legal kits.
Old Jun 11, 2005 | 11:25 PM
Jedi_Sol's Avatar
I failed cuz of my timing. Check your timing, make sure its between 14-18 BTDC.
Make sure your ecu doesn't have any CEL codes stored in there.
Make sure your evap purge control solenoid valve is hooked up to the ecu. Some places will use your evap purge connector to wire up the IAB's, so double check that.
Both refs i went to physically checked my ecu, checked to see if i have the H02 sensor, traced all the vaccum lines, checked the year of the motor, checked all of the eletrical plugs.
If i remember anything else, ill let u know.
James.
Old Jun 12, 2005 | 09:31 AM
JDMSiGuy17's Avatar
Default Re: HOW to BAR yur new engine swap? (Jedi_Sol)
search cuz there are some good threads about how to get bar'd
Old Jan 24, 2007 | 01:46 AM
mdd's Avatar
mdd
Default Re: HOW to BAR yur new engine swap? (JDMSiGuy17)
sorry to bump such an old thread.
but i was wondering when you buy carb legal parts do you buy it for the engine in the car or the car itself?
ie: comptech icebox? i have a civic coupe 98 and a gsr version of the ice box might not fit right? so which should i buy?
Old Jan 24, 2007 | 02:17 AM
slowpokecivic's Avatar
Default Re: HOW to BAR yur new engine swap? (mdd)
if your gonna get bar'd you buy it for the motor...
Touch
10
Oct 20, 2006 04:23 PM
Teg_Your_It
Jul 13, 2006 10:01 AM
jeffk182
12
Jul 9, 2004 10:12 AM
The Alchemist...
Oct 15, 2003 10:50 AM
EF-9SiR
18
Jan 10, 2003 12:10 PM
