Ref and Bar
Old Jun 30, 2006 | 06:17 PM
Teg_Your_It's Avatar
Default Ref and Bar
How much does it cost to get your car REF and BAR?
Whats the process that goes on when they REF your car?
A little new, just looking for answers.
Old Jun 30, 2006 | 06:19 PM
michael_c's Avatar
Default Re: Ref and Bar (Teg_Your_It)
30 to test (you get 3 tries) and if you pass an additional 8.25 for a certificate.
to go to the ref you need to have a reason such as being sent there or having a swap and the need to smog your car, but you cant just go there if you want to smog your car through them. basically they check to see if you have all of the proper smog equipment for the motor in your car, that is the visual part of the inspection. after that like at any other smog shop they put your car up on the dyno and measure the emissions to see if your a gross polluter (like me )
ive failed twice now and going in for a third time in a week or 2
Old Jun 30, 2006 | 07:49 PM
GoCarInteg's Avatar
Default Re: Ref and Bar (michael_cfh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michael_cfh &raquo;</TD></TR><TR><TD CLASS="quote">30 to test (you get 3 tries) and if you pass an additional 8.25 for a certificate.
to go to the ref you need to have a reason such as being sent there or having a swap and the need to smog your car, but you cant just go there if you want to smog your car </TD></TR></TABLE>
That's wrong. When I dropped the b20 into the integra, I went straight to see if I can get it smogged and if i needed to get it stamped. They will smog your car but it's cheaper to go elsewhere.
However, they do a detailed inspection of the motor and everything done to it.
To find a REF near you, just go to any automotive place (mechanic shop, dealer, etc.) and they will have a sign for BAR with the number. All you have to do is call the 800 number and you can find a place near you. GL.
Old Jun 30, 2006 | 08:13 PM
Thanks for the information! It will help alot!!! I thought it cost like 300 for them to go through and check it and what not.
Old Jun 30, 2006 | 08:16 PM
three stars, two bars's Avatar
From: knee deep among your wreckage and uncertainty
I'm so glad I've never had to deal with that ****, California is wack.
Old Jun 30, 2006 | 11:09 PM
TheCheeseWedge's Avatar
Default Re: Ref and Bar (GoCarInteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GoCarInteg &raquo;</TD></TR><TR><TD CLASS="quote">
except that you cant smog nor can you B.A.R. approve a b20 in any car seeing as it is a light truck/suv motor
Old Jul 1, 2006 | 11:58 AM
GoCarInteg's Avatar
Default Re: Ref and Bar (TheCheeseWedge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheCheeseWedge &raquo;</TD></TR><TR><TD CLASS="quote">
except that you cant smog nor can you B.A.R. approve a b20 in any car seeing as it is a light truck/suv motor</TD></TR></TABLE>
That's right in a sense...
I went to the REF and they told me that I didn't need to get my car restamped because I only went from a 1.8 to a 2.0. They did have second thoughts considering that it was a "light truck" motor but didn't see anything wrong with it. In other words, they did approve of it being in my car.
BTW,
I was able to smog my car.
Old Jul 1, 2006 | 05:45 PM
BTW,
I was able to smog my car. </TD></TR></TABLE>
thats pretty sick! lol you got lucky what one did you go to so ill know where to get a bar approved b20 lol
Old Jul 1, 2006 | 06:02 PM
michael_c's Avatar
the reason that worked out for you is that they did not really see that as a swap seeing as how you stated 1.8 to a 2.0 same motor series just larger there are no real differences besides the displacement.
and to find a ref near you call: 1-800-622-7733 its their phone number no need to drive around looking for a smog shop that says "bar" on it
Old Jul 9, 2006 | 09:07 AM
integra321's Avatar
i got a 94 ls if i swaped another 94 ls motor (since i threw a rod through the block), will i still need to get it bar or will it pass regular smog fine?? im in cali at the moment, not too familiar with this stuff thx
Old Jul 9, 2006 | 10:57 AM
DC2 Mang's Avatar
Default Re: Ref and Bar (loki719)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loki719 &raquo;</TD></TR><TR><TD CLASS="quote">i got a 94 ls if i swaped another 94 ls motor (since i threw a rod through the block), will i still need to get it bar or will it pass regular smog fine?? im in cali at the moment, not too familiar with this stuff thx</TD></TR></TABLE>
no cop will be any wiser to know, and most smog tech's won either, so I wouldnt worry about it because it is an identical replacement motor
the REF goes through a tight inspection checking all vacuum, evap, pcv, ecu and fuel system
you get 2 tries for $30, and $8.50 for the certificate, but i am not sure how much the BAR sticker costs
Old Jul 9, 2006 | 03:31 PM
BigD3154's Avatar
Default Re: Ref and Bar (DC2 Mang)
I wouldn't go through BAR! When i got a ticket for my header i replaced and had it smogged with them. I passed everything until they squeezed and stretched a coolant hose on my intake manifold. It barely dripped out and they failed me because it was a "hazard" and could overheat my motor. Avoid BAR if you can. And going through BAR could be 300 or more if you got a state ref ticket.
Old Jul 13, 2006 | 10:01 AM
Kangolbrand's Avatar
its a fix it ticket... how could it be 300 or more?
speedaholic92
226
Oct 21, 2011 10:50 AM
dj theoretic
Mar 29, 2008 11:13 PM
slo_ej8
Oct 28, 2007 05:19 PM
b-powa
Mar 13, 2004 07:10 PM
The Alchemist...
Oct 15, 2003 10:50 AM
