OEM foglights not turning on!
I have oem foglights on my car, theyve been working as long as i had the car (originally came with the car), and last night they stopped working. any ideas? is there a fuse i should check?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonnyr4c »</TD></TR><TR><TD CLASS="quote">by any chance would u happen to know which fuse it would be?</TD></TR></TABLE>
not exactly sure man. Check all of them and then check the fuse box in your engine bay. Just check to see if any fuses blew and if one is blown replace it and check the fog lights
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95civickid »</TD></TR><TR><TD CLASS="quote">its a single fuse by its self in its own holder should be yellowish to the right of the rest of the fuses</TD></TR></TABLE>
Well, mine is blue. Maybe it's JDM
. But yeah, there is an inline fuse on the right side of the fusebox.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jonnyr4c »</TD></TR><TR><TD CLASS="quote">is that fuse in the engine bay? or under the dash?</TD></TR></TABLE>
Under the dash onto the right of the fusebox if you car has OEM foglights. If they are Depo, the inline fuse is somewhere on the harness under the hood.
if there is a relay check it, mine did the same thing and the relay was still clicking problem was that inside the relay was so corroded that not enough current could pass through the wire to make the relay click over. Good luck
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaiba »</TD></TR><TR><TD CLASS="quote">Check you ground wire.</TD></TR></TABLE>
That's what I'm voting for, I've had similar issues with bad grounds.
truevietluv636
Mar 1, 2007 09:46 PM
