I bought an msd digital window switch need help
k i bought MSD DIGITAL WINDOW SWITCH but theres something i can't figure out
RED WIRE= POSITIVE
BLACK= NEGATIVe
WHITE= NEGATIVE COIL
THEN my problem is with output wires
GRAY SAYS NORMALLY CLOSED. THIS WIRE WILL REMOVE THE GROUND SOURCE AT UR DESIRED ON RPM, AND COMPLETE THE GROUND CIRCUIT AT THE SET OFF RPM
YELLOW NORMALLY OPEN. THIS WIRE WILL PROVIDE A GROUND SOURCE AT UR DESIRED ON RPM AND REMOVE THE GROUND AT THE SET OFF RPM
and it says that yellow goes to the solenoid or gray so what do i do connect both of them 2 the same solenoid ??
oh and this is for a nitrous set up
Modified by Slammed92hbonN20 at 1:07 AM 6/10/2005
Modified by Slammed92hbonN20 at 4:01 AM 6/10/2005
here is a link of the instructions http://www.msdignition.com/pdf/8969_frm25515.pdf
one side of the solinoid will be +12v the other side will be to the yellow wire
will ground at 3000 rpm and disconnect ground to 8200 rpm.
if wide open throttle and arming switch is on.
You've got two outputs: 1 of them is normally closed which means that when you are NOT in the window, its closed and when you are in the window, its open. Then you have another output that is normally open and displays the opposite behavior of above.
The outputs are activated by the same circuit, so when you get to the 'on' rpm, one output opens up and the other closes. Its just a way of providing flexibility to the end user.
racingant
Jan 11, 2004 05:15 PM
