weird idle, bogging, choking after plugging in p2t ecu
Old Jun 9, 2005 | 11:59 AM
hifi_civic's Avatar
Default weird idle, bogging, choking after plugging in p2t ecu
when i had the p2e ecu plugged in, car was running fine. after i plugged in a p2t ecu from a 2000 civic si, my car had a weird idle, and when i tried to drive it, it was bogging, and it wouldnt grab. im using this ecu for my mini swap and i just wanna get this **** done already. thanks for any help
Old Oct 5, 2011 | 08:33 AM
91crxsikenny's Avatar
Default Re: weird idle, bogging, choking after plugging in p2t ecu
Ur ecu may not be compatible with ur distributer
Old Oct 5, 2011 | 08:38 AM
grumblemarc's Avatar
The Grumpiest
Not understanding. The P2E worked fine? Maybe you need to furnish more info on the setup to stop people from guessing.
Old Oct 5, 2011 | 11:29 AM
HondaPartsHero's Avatar
Technical Hero
Sounds like you probably have at least one check engine light. I'm going to guess one of the lights is for idle air control. You have to convert from 3 wire to 2 wire. Did you wire up VTEC? Knock sensor? Extend the secondary O2?
lsvtec101
Jan 2, 2013 04:39 PM
dank24
24
Jul 28, 2006 02:42 AM
mikeunreal2
21
Apr 13, 2006 06:36 PM
B-SerioUs EGg
Dec 29, 2005 06:49 AM
danslerugueux
18
May 15, 2004 01:12 PM
