V-tec or Turbo
well i have a 1995 4 door acura integra LS ryte now and i want to make it faster but wah should i do to it. Put a v-tec head and make it a LS v-tec or put a turbo in it and make it a LS turbo. I mean i would add both but then the LS block is pretty weak n i dont want to put to much power in that thing or it might blow up so give me suggestion and i'll see wassupz. I also know know v-tec is cheaper but it give less hp as turbo but turbo would cost more......so???
I would go with a turbo setup. You will not be disappointed in the ls turbo. the m ost u can run on a stock ls block is abnout 8 to 10 lbs of boost without having any problems.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keangdawizes »</TD></TR><TR><TD CLASS="quote">well i want a turbo too but do anyone know how much hp a turbo would give and how bout adding v-tec</TD></TR></TABLE>
it depends on the setup/turbo and the condition of the motor. 250~300whp isn't hard to achieve on a stock motor ls.
an ls block would handle close to as much power as a v-tech block mYte, honestly if you want power go turbo. If you do, you have much studying ahead of you my friend
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda011 »</TD></TR><TR><TD CLASS="quote">ls-vtec turbo or if not both ls turbo..</TD></TR></TABLE>
^ I'm loving it!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shermanyang »</TD></TR><TR><TD CLASS="quote">
it depends on the setup/turbo and the condition of the motor. 250~300whp isn't hard to achieve on a stock motor ls.</TD></TR></TABLE>
^ Sherman has a crazy LS setup. You want to make power from an LS? Ask Sherman. You hit 400whp yet Sherm?
^ I'm loving it!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Keangdawizes »</TD></TR><TR><TD CLASS="quote">well i have a 1995 4 door acura integra LS ryte now and i want to make it faster but wah should i do to it. Put a v-tec head and make it a LS v-tec or put a turbo in it and make it a LS turbo. I mean i would add both but then the LS block is pretty weak n i dont want to put to much power in that thing or it might blow up so give me suggestion and i'll see wassupz. I also know know v-tec is cheaper but it give less hp as turbo but turbo would cost more......so???
...is Sh!ttyLS gonna have to choke a bitch?
j/k
. But yeah LS blocks aren't that weak, I think 8-10 pounds on a stock bottom end is decent for a car that was never meant to have a turbo on it in the first place.
j/k
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by old_school_dohcvtec »</TD></TR><TR><TD CLASS="quote">id do engine swap to b18c5
the ultimate b series engine</TD></TR></TABLE> ultimate b series stock yea but not ultimate out there. But yea, i'd do ls turbo, i got ls/vtec and i think you'd be better off turbo cause integs are ****** pigs. they weigh alot.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaydeemmmm »</TD></TR><TR><TD CLASS="quote">
^ Sherman has a crazy LS setup. You want to make power from an LS? Ask Sherman. You hit 400whp yet Sherm?</TD></TR></TABLE>
not yet, i haven't gotten her dyno tunned yet and my WB O2 is dead. so all i'm doing now is breaking her in slowly. cam tunning on boost with the 404's is crazy and hard without a dyno.
Just got LS turbo. Drag makes a great kit so does rev hard and they come with pretty much everythitng you need. Other then that you just need a proper exhaust and there you go. With proper traction 13s are no problem. I think you should first think about some goals though before you even decide what setup you wanna go with. How much money you want to spend? Do you want something reliable and pretty maintenance free? All questions you should ask yourself before deciding which route to go.
wow i guess everyone wants it to be turbo.. and yea it would cost more n stuff but its gonna be pretty good.
pharcyde yea i been askin all those question to myself too haha.. like i know imma be smashin n stuff on it so with turbo or v tec n stuff.. i did thought about just leaving it to a LS but i want it to be faster
shermanyang i guess i might be needing ur help later on when i want to fix up my integra some more
but thanx everyone i guess i might go with turbo ryte now then but imma be saving for awhile for it so thanx
shermanyang i guess i might be needing ur help later on when i want to fix up my integra some more</TD></TR></TABLE>
yeah not a problem. that's what this site is for
one thing before you start building your project car...don't just buy any'ol part thinking you'll make power from it. read up about the part, about people who have the part, and what the pros and cons of the part are. that way, you'll know what you're getting yourself into before you throw away money. oh...and learn more about velocity stacking and 'flow' before you start. this way you'll know what it takes to make power from an LS motor.
chewymonster
10
Feb 14, 2007 08:10 AM
my ride
Apr 21, 2004 01:28 PM
