Which springs can I use on my integra to lowering it -40mm or more?
Old Jun 7, 2005 | 02:08 PM
HONDA_TEG's Avatar
Default Which springs can I use on my integra to lowering it -40mm or more?
Hi Can anyone tell me what springs can I use on my Integra type-r 1996 to lowering it -40mm or more? Thanks guys
Old Jun 7, 2005 | 02:19 PM
p nut's Avatar
You have to specify why you are lowering it. For looks? Performance? What do you use your car for--mostly street driving or mostly track? etc etc.
But to generally answer your question, getting a nice set of coilovers will take care of your needs.
Old Jun 7, 2005 | 02:24 PM
Chris F's Avatar
Default Re: (P Nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut &raquo;</TD></TR><TR><TD CLASS="quote">But to generally answer your question, getting a nice set of coilovers will take care of your needs.</TD></TR></TABLE>
Omnipower (sports at least) can get you low, probably 2-2.5 inches lower. ~5-6 cm. I like them for the track, and I could have that slizzamed look if I wanted it.
I had to raise it because of rubbing on my wrong-size tires. Now I have the right offset and it never rubs.
I am not near the limit as to how low these can go.
-Chris
Old Jun 7, 2005 | 02:30 PM
Chris F's Avatar
Default Re: (P Nut)
Yeah, if you care about looks at all, coilovers are great because you can raise or lower the car in about 15-20 minutes (an hour if you suck at it like me). So you can take it right down to where you have rubbing problems, then raise it up a bit.
Omnipower street (10k/8k) and sport (12k/10k) coilovers are $649 from kteller.
http://www.kteller.com/store/i...5_228
You may want to search honda-tech to see if they have a deal running on them.
CRAP-- 1996? What rear LCA's are those, will the normal Type R bolt up or GSR?
Old Jun 7, 2005 | 02:45 PM
p nut's Avatar
Yeah, Omni's are nice. BC's also seem to have really good reviews. I'm still a track-noob trying to get the most out of my stock setup.
Old Jun 7, 2005 | 04:55 PM
Chris F's Avatar
Default Re: (P Nut)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P Nut &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, Omni's are nice. BC's also seem to have really good reviews. I'm still a track-noob trying to get the most out of my stock setup. </TD></TR></TABLE>
There's a ton of coilovers out there, many that are better than Omni, but I would give Omni a two-thumb-up for bargain!
Old Jun 7, 2005 | 05:42 PM
metal-x's Avatar
Default Re: (Chris F)
Chris how do you like the Omni's on the street? im really considering getting them for my R
Old Jun 7, 2005 | 05:43 PM
Chris F's Avatar
Default Re: (metal-x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by metal-x &raquo;</TD></TR><TR><TD CLASS="quote">Chris how do you like the Omni's on the street? im really considering getting them for my R </TD></TR></TABLE>
They're awesome. I've driven them from Chicago to VIR, Chicago to Expo, only one of those legs did I end up with a sore back.
I do spend a little time in the air on large bumps, but I think you're destined for that with 10K rears.
They take curbs on tracks with confidence
Y-eight
Jul 22, 2011 11:06 AM
s2k3_oc08
Suspension & Brakes
Mar 12, 2006 06:20 AM
jayfowens
Jul 8, 2005 06:48 PM
jdmspoonitr
Feb 24, 2004 01:38 PM
GsR HtCh
12
Jul 25, 2002 05:39 AM
