what can happen when....
From: Formerly of SF moved to DFW and now back in SF, CA, USA
I've slammed on my brakes to avoid an accident without depressing the clutch pedal and it just killed the engine not the tranny. That's weird your's busted up. Maybe there's a nother reason?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by carbing’ed »</TD></TR><TR><TD CLASS="quote">you have to brake so fast that u forget to depress the clutch while you are braking?
tranny messed up?
downtown owned me
Similar to stalling in first on start up (engaging the clutch with out sufficient throttle)...
tranny messed up?
downtown owned me
</TD></TR></TABLE>Similar to stalling in first on start up (engaging the clutch with out sufficient throttle)...
tranny messed up?
downtown owned me
This happened to me, in a higher gear (forget which) the engine didn't stall it just felt like it bounced off the rev limiter for a second before I caught it. Should be ok I think, although I wouldn't make a habit of it.
tranny messed up?
downtown owned me
</TD></TR></TABLE>This happened to me, in a higher gear (forget which) the engine didn't stall it just felt like it bounced off the rev limiter for a second before I caught it. Should be ok I think, although I wouldn't make a habit of it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nishant »</TD></TR><TR><TD CLASS="quote">engine will stall, won't damage anything</TD></TR></TABLE>
That's what I thought.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Racermech »</TD></TR><TR><TD CLASS="quote">For some reason i have trained myself to pres the cluth when i have to slam the brakes. I usually hover my foot over the clutch. That is just me.....and I am weird
i do the same as you its just a habit for me now
</TD></TR></TABLE>i do the same as you its just a habit for me now
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1122itr01 »</TD></TR><TR><TD CLASS="quote">i do the same as you its just a habit for me now</TD></TR></TABLE>
same here
same here
Thats what i do usually...just forgot one time. Maybe I though I was in my girlfriends GS auto
</TD></TR></TABLE>Thats what i do usually...just forgot one time. Maybe I though I was in my girlfriends GS auto
tranny messed up?
shouldn't have...if anything it should have just stalled the motor and it shut off.
tranny messed up?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jon D »</TD></TR><TR><TD CLASS="quote">
shouldn't have...if anything it should have just stalled the motor and it shut off.</TD></TR></TABLE>
when you let go of the brakes, it should automatically turn on if your still in gear.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IVI »</TD></TR><TR><TD CLASS="quote">
providing you have enough momentum
There is an important exception to the no damage thing. If you spin the car and don't put the clutch in you can fry stuff big time from suddenly reversing the direction of travel. So, "in a spin, both feet in."
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 00R101 »</TD></TR><TR><TD CLASS="quote">There is an important exception to the no damage thing. If you spin the car and don't put the clutch in you can fry stuff big time from suddenly reversing the direction of travel. So, "in a spin, both feet in."</TD></TR></TABLE>
Whatever, power through it!!!!
More gas!
(I wouldn't really recommend that, but have done it in autocross to avoid flat-spotting.)
More gas!(I wouldn't really recommend that, but have done it in autocross to avoid flat-spotting.)
Vp Special K
Aug 25, 2004 10:08 AM
Kusai.Nihonjin.Desu
Sep 28, 2003 07:09 PM
