B16a0 = codes 43 & 44 (Engine light lit)
What could cause this problem, i have very lumpy and erratic idling.
The car has been parked up for three years, alot of black carbon deposits come out the exhaust,
What do i check first?
Thanks
Harry
Thanks
Harry
codes 43 and 44 are for fuel supply problems, i have taken off the fuel regulator and i sprayed it with wd40 to loosen it up, i am going to check the injectors later, where is the fuel filter located?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by harryr34 »</TD></TR><TR><TD CLASS="quote">codes 43 and 44 are for fuel supply problems, i have taken off the fuel regulator and i sprayed it with wd40 to loosen it up, i am going to check the injectors later, where is the fuel filter located?</TD></TR></TABLE>
...last time i checked...it was on the fire wall
weirdone86
Sep 14, 2006 07:35 AM
