Suspension & Brakes Theory, alignment, spring rates....
How does a camber kit work?
Old Jun 6, 2005 | 01:14 PM
JDR's Avatar
JDR
Default How does a camber kit work?
All these camber kits say -1.75 to +1.75 degrees.. what does this mean?! i dont get it can someone help me does the +1.75 correct the -1.75 to make the camber 0 or does it just correct positive camber?
Old Jun 6, 2005 | 01:29 PM
fireant's Avatar
Default Re: How does a camber kit work? (JDR)
From what I've seen, the listed numbers are the range of adjustment relative to whatever you currently have.
So if you start with -2°, the kit will allow you to theoretically get from -3.75° to -.25° or anywhere in between.
Old Jun 6, 2005 | 01:57 PM
JDR's Avatar
JDR
uhh i dun get it still..
lemme use a different example...
if the degrees were -.75 to +3.00 what the does that mean? Does that mean if u start off with say -1.3 camber?
Old Jun 6, 2005 | 03:39 PM
nonsense's Avatar
Default Re: (JDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDR &raquo;</TD></TR><TR><TD CLASS="quote">uhh i dun get it still..
if the degrees were -.75 to +3.00 what the does that mean? Does that mean if u start off with say -1.3 camber?</TD></TR></TABLE>
ok so you lower you car and now you have -1.3 camber. The "-.75 to +3.00" kit will allow you to adjust it to -2.05 to +1.7.
Say you drop the sh*t out of your car and somehow end up with -3.00 camber, you can use that kit to change it to -3.75 to 0.
Old Jun 6, 2005 | 04:18 PM
JDR's Avatar
JDR
Thank you so much that was much more clear.
Dirty Octopus
28
Feb 20, 2010 05:47 AM
tangou
Sep 27, 2007 06:20 PM
Kyles ej1
26
Nov 19, 2004 06:09 AM
tshaw
Dec 30, 2003 10:43 AM
vbspec
Oct 8, 2003 04:52 AM
