Those running standalone, whats the optimal A/F ratio in partial throttle?
Old Jun 5, 2005 | 09:00 AM
VSBB6's Avatar
Default Those running standalone, whats the optimal A/F ratio in partial throttle?
I know it can be leaner than 13.7 since this is not full load, but what is the safe range I should be tunning at? 14.5-14.9?
thanks!~
Old Jun 5, 2005 | 09:41 AM
Used2beAb16's Avatar
Default Re: Those running standalone, whats the optimal A/F ratio in partial throttle? (VSBB6)
how much throttle? Lite throttle thats mid 14's should be fine. (if your not knocking) Whats the compression, octane, timing, etc.
Old Jun 5, 2005 | 10:35 AM
mastarolla's Avatar
Default Re: Those running standalone, whats the optimal A/F ratio in partial throttle? (Used2beAb16)
The compression and timing are gonna be critical factors.... For instance i once ran a factory B16 @ a little over 15:1 and never had an issue
On our race builds we try to run around 14 - 14:3.
MalcolmV8
Nov 15, 2012 11:05 AM
jdmcivic2fast
May 26, 2011 12:59 PM
anth2k4
Mar 25, 2008 06:20 PM
Tommy_Gunns
Dec 20, 2001 11:01 AM
