Compression test...oops
Old Dec 20, 2001 | 01:33 AM
Tommy_Gunns's Avatar
Default Compression test...oops
Ooops...just finished doing a compression test. But I forgot to press the throttle all the way down while I cranked the motor. How off is my results from not doing this?
What is the purpose of holding down the gas pedal while cranking? Is it to ensure the throttle butterfly valve is open so the intake can suck air into the cylinders? Are you suppose to crank the motor (in 3-4 second spurts) till the pressure no longer moves on the gauge tester?
Old Dec 20, 2001 | 05:15 AM
typer_801's Avatar
Default Re: Compression test...oops (Tommy_Gunns)
Can't comment on how far off your results are. I'd suspect they're way off, but that's my seat of the pants guess, since the throttle was closed. Should be in the "200's" if your motor is in good working order. If not, re-test the correct way.
Old Dec 20, 2001 | 05:44 AM
Mike K's Avatar
Default Re: Compression test...oops (typer_801)
With the throttle open on mine, the results were only 10 psi higher.
Throttle closed: 235-240
Throttle opened: 245-250
For compression comparison, I have a B18C5, head milled 12 thou(11:1 or so)..
Old Dec 20, 2001 | 10:58 AM
Default Re: Compression test...oops (Mike K)
Thanks Mike. My results were as follows (with the throttle closed):
215-205-215-215
In cylinder number 2 (I got 205 psi on), there were rust colored stains on the spark plug boot and on the ceramic of the spark plug. This is an indication of moisture or water present on the boot at one time or other? Anything to be concerned about?
Does anybody have pics of a brand new stock ITR spark plug? Mine looks like the electrode is worn but it might just be that way stock.
Old Dec 20, 2001 | 11:01 AM
HX_Guy's Avatar
Mine were pretty much the same with throttle closed or opened.
250-255 PSI @ 7 cranks
rmrider12522
Mar 1, 2014 08:16 AM
anth2k4
Mar 25, 2008 06:20 PM
drumminforev
13
Sep 19, 2006 05:42 PM
Sprockets
Jan 23, 2003 07:01 PM
