compression testing?
Old Mar 25, 2008 | 04:16 PM
anth2k4's Avatar
Default compression testing?
Hi I'm just wondering how many times should you crank the ignition while doing a compression test? I was told 5-7, but I noticed my compression kept going up until 9-10 times. Also is it alright to release the throttle between cranks (I just presss the gas pedal down) or should throttle be held open during every cylinder test ( i.e. zip tieing the throttle open) Thanks.
Old Mar 25, 2008 | 06:20 PM
91DA9's Avatar
Default Re: compression testing? (anth2k4)
Yeah, 5-7 should really do it. Make sure to have all your plugs out when doing it, though.
It is fine to close the throttle when not cranking. Just remember to go back to WOT before testing the next.
yomama07024
Jun 10, 2013 10:22 AM
umair
Dec 7, 2009 10:37 AM
1992cxhatchB16A2
Oct 21, 2008 06:42 PM
Sprockets
Jan 23, 2003 07:01 PM
