how lean can u go?
Old May 23, 2011 | 08:23 AM
jdmcivic2fast's Avatar
Default how lean can u go?
just got my stock bottom end lsvtec turbo motor tuned and running around 15:1 afr @ crusing/part throttle. seems like its hogging more gas than when it was all motor, it was tuned around the same afr on part throttle as the turbo-setup when it was all motor. how lean can my turbo set-up be tuned on part throttle to run safely?
Old May 23, 2011 | 08:43 AM
Bizzle5OH3's Avatar
Default Re: how lean can u go?
14.7 is just about perfect ( depending on who you ask ) While boosting you wanna be around 12.5-12 ( again, depending who you ask )
Old May 23, 2011 | 11:18 AM
LocoJoe's Avatar
In cruise, 14-15 AFR should be good, EGT temps might get a little high so depends on what u and ur tuner want. 13s sound safe for me. Under full boost depends on what fuel you using. Pump gas I dont run more than 11.6 - .8 Race gas might get a little leaner. This also depends on timing. I dont run anything leaner than 11.6 and 25 degrees of timing just to be on the safe side.
Old May 23, 2011 | 11:40 AM
civickiller's Avatar
I tuned my car 1 point leaner except for WOT
Old May 23, 2011 | 11:44 AM
non-VTEC's Avatar
under very light throttle/cruise i tuned it to run around 15.5-16:1. 14.7:1 in most parts. if im easy on the throttle i can get over 30mpg easily.
Old May 23, 2011 | 12:00 PM
I shoulda put my mpg too
I get 35 mpg city, b16 tranny
with a ls tranny, I got about 39mpg
Old May 23, 2011 | 12:15 PM
turbociv910's Avatar
14.7-15.0 cruising
aim for 11.5-11.8 using 93
12.5 using my custom mix
Old May 23, 2011 | 12:19 PM
Garage 808 Hatch's Avatar
it may be a leaner mixture, but I bet its cruising in a higher column, using more fuel
Old May 23, 2011 | 12:50 PM
Turbo-LS's Avatar
x2
What trans is in this car? How far form the turbo is the Wideband sensor located? The a/r ratio is fine for part throttle. Make sure no exhaust leaks at all this will also throw leaner readings. no reason you can't get 30+ out of it though. if its getting horrible gas milage then something is up with it.
Old May 23, 2011 | 07:18 PM
Sr420Det's Avatar
lean burn limit of a gas efi motor is 18-22:1, i run 18 19 cruising which is about the limit of the wideband. the tradeoff is emissions
Old May 23, 2011 | 07:50 PM
pwebb0207's Avatar
direct injection now allows for as lean as 40:1 ... iirc
word?
Old May 23, 2011 | 08:08 PM
Sr420Det's Avatar
yep but not stock on our fuel, what does iirc mean
Old May 23, 2011 | 08:33 PM
spoolie's Avatar
iirc=if I recall correctly
interstate no boost/load...17.0
Old May 24, 2011 | 03:37 AM
Turbo-LS's Avatar
you shouldnt run really lean, it really heats things up and high egt's arent that great for anything
Old May 24, 2011 | 04:54 AM
non-VTEC's Avatar
running it leaner at very light loads wont really hurt anything.
Old May 24, 2011 | 09:04 AM
darkvader0's Avatar
I'm running 17.5:1 (equiv.) up to 55kpa using E85. Getting about 22MPG with that lol. Not sure what I would risk on 93.
Old May 24, 2011 | 12:26 PM
Sr420Det's Avatar
not nec true, no worries for such a light load. More heat means more power for cruising, its a good thing and the flame front goes super slow so u may need to add a lil timing for such lean afr's
Old May 24, 2011 | 12:53 PM
x2
stock GSR trans
no wide band, got readings of of dyno when doing part throttle tunning.
I need to check for leaks cause i do smell rich burn fuel.
Old May 25, 2011 | 06:15 PM
wel i kinda calculated how much mpg i get and it seems like its about 25mpg if i push it.
my car was on E, so i pumped 20 bucks which is about 4.77 gallons, cause gas here is $4.19 per gallon, and i ended up with 110 miles. this is just cruzing in town and highway. I only floored on it 2 times in 2nd gear.
110 miles / 4.77 gallons = 23 mpg
this is still a gas hogger in my opinion. what do u guys think?
Old May 25, 2011 | 06:45 PM
pwebb0207's Avatar
best way to calculate:
fill up - do not top off, set trip meter to 0, and drive
on next fill up make note of exact gallons filled - again do not top off
divide gallons used into miles driven
voila.
if possible use the same gas station and pump
Old May 26, 2011 | 08:49 AM
whats a good radiator to use?
Im using a dual core stock 92-95 civic radiator and stock fan and im getting very high temperature reading, so i have to constantly have the fan on just to keep the temperature in check.
Old May 26, 2011 | 12:18 PM
Muckman's Avatar
Moderator in Chief
You can lean it out alot when cruising/light load. There is a threshold where its so lean the engine cannot sustain the speed requiring more load and more fuel. I usually tune my cars for 15-16:1 AFR part throttle but have experiemented as lean as 18:1 without driveability issues. You arent going to hurt anything under light load, worse case it just wont drive good.
Old May 26, 2011 | 12:59 PM
rich7777's Avatar
That is exactly how it is.
booboo782
Engine Management and Tuning
Feb 3, 2014 06:28 PM
gt35rSI
Mar 29, 2008 08:25 PM
VSBB6
Jun 5, 2005 10:35 AM
mskibbz-T
Jul 21, 2003 10:41 PM
