t3 vs t3/t4
on a honda motor t3 vs t3/t4 at the same boost leaval will u make more hp with the t3/t4 if so how much more u think
t3 with a .60 comp/.63 ex housing with a stage 1 wheel
t3/t4 like the one that come's with the drag and revhard kit
at about 10-16psi
on a h23 motor but it should be about the same as b18 gain h23 just got more hp stock
at about 10-16psi
the t3/t4 hybrid is going to produce more power than pretty much anything with a t3 compressor.
do you think that a 60-1 turbo is too big for a 2.0 liter ls/vtec fully built longblock with a stand alone running 10psi on the street and 20+ at the track??
[Modified by internet ay, 12:52 PM 2/9/2002]
At the expense of spool-up time. A T3/T4 will take longer to get into boost, and hit full boost than a T3 turbo. There is suck a thing as "too big" of a turbo for a setup. I think a T3/T4 is too big for a D16 engine, for example.
um, no. the T3/T4 uses the T3 exhaust housing so you have the exact same spool up time as a T3 with the same turbine configuration. just a bigger compressor wheel. more power at same boost.
Also, the turbine is driven by exhaust gas.... that originally came in as mixture from the intake manifold... and the air came from the compressor....
Dustin
93LSivic, you are right. For the B20Z, which has a 3.30" bore and 3.50" stroke, at 20Psi, the compressors that put it under the surge limit are the T3 Super 60 and the TO4E 40 and 46 trim. My reference is http://www.turbofast.com.au/turbomap.html
The 60-1 will not work at that boost level on the B20Z.
I took my drag3 turbo apart and polished the inside of it, well the parts i could see, it looks like a mirror, and now the turbo spools up a good bit faster, oh and without my cat on the car it feels as it spools up faster than my old greddy setup.
Mugencrxsir1
Feb 26, 2006 04:17 PM
Andrew 825SM
Jun 20, 2002 12:04 AM
