Those running standalone, whats the optimal A/F ratio in partial throttle?
How much leaner can I run and still be safe? 14.5 -14.9?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by homesauce »</TD></TR><TR><TD CLASS="quote">Yes, if it's not at full load, you can run it leaner.</TD></TR></TABLE>
If by partial throttle you mean cruising, then close to 14.7 is fine, maybe a little under to compensate for load changes. If you mean light acceleration, then it's still good to have a little extra fuel around 13.7-14. For WOT I have it around 13.2-13.5. Is 13.7 more optimal for NA set ups at WOT?
At anything but WOT you want to be as close to stoich as possible (14.7:1). I know people who actually run it a little lean (15.2:1) in 5th so when they're cruising long distances they get better mileage, usually these cars are running on higher octane though.....
at partial throttle you should have a closed loop map that runs off the o2 sensor
at WOT you should be on open loop map and not using the o2 sensor
closed loop stays around 14.7 i thought and might even try to lean it out more? iono
open loop should stay at what... 13.2? whatever is good for WOT
least that the jist of what i undersatnd
booboo782
Engine Management and Tuning
Feb 3, 2014 06:28 PM
