Redline to 4th gear....not going in?
Old Jun 3, 2005 | 11:29 PM
trooper0641's Avatar
Default Redline to 4th gear....not going in?
Redlining 3rd into 4th...but gear doesnt want to go in. Does anybody have a simuliar problem?
Old Jun 3, 2005 | 11:34 PM
mula's Avatar
Default Re: Redline to 4th gear....not going in? (trooper0641)
how is your clutch ?
Old Jun 3, 2005 | 11:37 PM
Default Re: Redline to 4th gear....not going in? (mula)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mula &raquo;</TD></TR><TR><TD CLASS="quote">how is your clutch ?</TD></TR></TABLE>
my clutch is okay i guess. its not the best but it still grabs okay for stock.
Old Jun 4, 2005 | 09:50 AM
43rweffsdf
Old Jun 4, 2005 | 12:41 PM
blah blah
Old Jun 4, 2005 | 03:44 PM
q3wfwesdfsdf
Old Jun 4, 2005 | 04:37 PM
ZedEx's Avatar
It may be easier to just type "Bump"
Perhaps it's you Syncros?
Old Jun 4, 2005 | 04:43 PM
JDMisGOOD's Avatar
Default Re: (ZedEx)
how's your fluid level? does it grind? or just not want to go in? have u tried double clutching and/or rev matching?
Old Jun 4, 2005 | 10:30 PM
Default Re: (JDMisGOOD)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMisGOOD &raquo;</TD></TR><TR><TD CLASS="quote">how's your fluid level? does it grind? or just not want to go in? have u tried double clutching and/or rev matching?</TD></TR></TABLE>
fluid is good, does not grind 4th but does grind high 3rd. I dont do any fancy shiftings...just quick shifts. ill try to go slower the next time i get into 4th and see what happens.
Old Jun 4, 2005 | 10:32 PM
fishnfst's Avatar
The single cone synchros in the d series trannies don't do well at high rpm's.... Have you checked your master and slave cylinders... Maybe your hoses are getting fatigued and you are losing some pressure in the flex of the hose....
james p.'s Avatar
Default Re: (trooper0641)
I say clutch
creator1322
Sep 27, 2008 04:52 PM
Deano_D aka "Brick Top"
Sep 22, 2008 08:37 PM
wrice4
Honda S2000
14
Dec 8, 2007 09:33 PM
98LS4dr
Dec 15, 2005 03:38 AM
Wuman
May 5, 2005 12:44 AM
