Kaaz LSD Question????
Old Jun 3, 2005 | 08:10 PM
gsr_hatchback's Avatar
Default Kaaz LSD Question????
for those of you that have a kaaz lsd, i just installed one in my b18c tranny. i noticed a winning noise when deaccelerating in nutral or any other gears. is this a normal noise? i am not sure if it is, i have never deiven in another car with a kaaz. thanks for all the help.
Old Jun 4, 2005 | 09:01 PM
Default Re: Kaaz LSD Question???? (gsr_hatchback)
anyone????
Old Jun 8, 2005 | 03:48 PM
pgpunkguy's Avatar
did you do the normal break-in?
are you using kaaz tranny oil?
of yes to both... yes, there often is some noise with these lsd's... after some time it usually goes away...
Old Jun 8, 2005 | 03:49 PM
pgpunkguy's Avatar
Default Re: Kaaz LSD Question???? (pgpunkguy)
out of curiosity where did you get your lsd and for how much?
Old Jun 8, 2005 | 09:02 PM
yea i broke it in, and yes i used kaaz oil.
i got a fully built trans. from a friend, with no miles on it for $1700. it has a aftermarket 1 and 2 gear (i dont remember what right now) ls 5th gear, and a shorter finaldrive (shorter than a type R), and the Kaaz. i know that everything was installed right, and broken in right. i was just conserened about the noise when slowing down. it kind of sounds like it does when in reverse, or if i had straight race gears (like the reverse gear) any ideas? thanks for the help.
Old Jun 8, 2005 | 09:06 PM
dont ger me wrong, i dont mind the noise. i just want to know that it is a normal noise, and that nothing is fucked up. thanks again.
Old Jun 9, 2005 | 08:37 AM
pgpunkguy's Avatar
yeah some noise is pretty common... usually goes away after a while
Old Jun 9, 2005 | 01:10 PM
2000ex's Avatar
http://www.amsoil.com/storefront/ada.aspx
i used this in my gsr tranny with a quaife lsd. it works awesome. i just put one little bottle in with honda mtf.
Old Jun 9, 2005 | 02:27 PM
Default Re: Kaaz LSD Question???? (2000ex)
^^^thanks, i will have to try it.
AccordtypeT
Transmission & Drivetrain
Apr 12, 2011 02:41 PM
drSquish
May 28, 2008 12:15 PM
ITR_HO
Feb 9, 2007 03:02 PM
vtecb20coupe
Apr 17, 2006 07:58 AM
JDMCRX
Jun 6, 2004 04:45 PM
