Having o2 sensor problems...........again...........
Old Jun 3, 2005 | 07:57 PM
WildPig's Avatar
Default Having o2 sensor problems...........again...........
While I was swapping in my y8 head last weekend, I put in a y8 engine harness to "make the swap easier." After all this, I wish I just modified my dx harness.
Everything is working fine except I'm throwing a code "65 Secondary oxygen sensor heater." Today I tried to wire the o2 sensor directly to the ecu, but had no luck, it's still throwing the same code after resetting the ecu.
Here is my diagram that I am trying to use to wire it up:
Now my question is: did I wire this up correctly? I assume that:
green/black = heater wire
white/red = signal wire (may need to be shielded? I dont know?)
black/white = power
black/yellow = ground
And from this pinout I found for my obd2 y8 ecu, I thought this would work, I soldered the connections and everything too.
Please, I need some help.
Old Jun 3, 2005 | 08:16 PM
WildPig's Avatar
Default Re: Having o2 sensor problems...........again........... (WildPig)
Am I connecting the power and ground wires right? Should I use B1 for power and B20 for ground? Thats the way my vafc2 is wired up and it works perfectly.
Are B9 and B10 only used for accessories or something? I don't get why this isn't working if it is wired DIRECTLY from the secondary o2 to the ecu..............
Come on, somebody has had to do this before.........
Old Jun 3, 2005 | 08:50 PM
WildPig's Avatar
Any help?
Old Jun 4, 2005 | 08:23 AM
.Nomad.'s Avatar
Bump this....... I still need help.
Old Jun 4, 2005 | 08:27 AM
WildPig's Avatar
Default Re: Having o2 sensor problems...........again........... (revolutionaryracer)
^^^^ My bad I was logged in as my brother.
Somebody has had to of done this before, a little help please?
Old Jun 4, 2005 | 08:42 AM
nocturnaldragon's Avatar
if its the heater, the sensor portion is working fine its the heating element thats not working correctly check the heater side of the circuit not the sensor.
Old Jun 4, 2005 | 08:50 AM
WildPig's Avatar
Default Re: Having o2 sensor problems...........again........... (nocturnaldragon)
It threw me only a code 65 when the sensor wasn't wired up at all, so I'm trying to get the power and ground sorted out too (and signal for that matter).
I am trying to wire it directly to the ecu so right now and I don't know what I'm doing wrong.
Please look at my diagram and tell me what I'm doing wrong.
Old Jun 4, 2005 | 09:11 AM
civictildeath's Avatar
i think that pic is wrong. you do have a P2P ECU right??
A5- Black/White heater
D13- Green/Black Ground
D14- White/Red Signal
other wire goes into main harness and i have no clue what for
do you have a helms??
check o2 sim install thread in my sig below NOTE: black wires in pic are labeled backwards!!!!!!!!!!
Modified by civictildeath at 1:22 PM 6/4/2005
Old Jun 4, 2005 | 09:27 AM
Default Re: Having o2 sensor problems...........again........... (civictildeath)
ya image is definately wrong
follow wiring for OBD2A B16A3 click here
Old Jun 4, 2005 | 10:54 AM
WildPig's Avatar
Thanks but that didn't help me AT ALL.......... That pic I have is obd2b for a reason: it's because my car is a 00 civic with a y8 head and y8 engine harness and it is obd2b not obd2a.
All I need to know is if this is right:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WildPig &raquo;</TD></TR><TR><TD CLASS="quote">
black/white = power
So can anybody tell me?
Old Jun 4, 2005 | 10:57 AM
WildPig's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civictildeath &raquo;</TD></TR><TR><TD CLASS="quote">A5- Black/White heater
D14- White/Red Signal</TD></TR></TABLE>
Wait, so you're telling me that the black/white wire is the heater wire? And the green/black wire is ground?
Can anyone confirm this?
Old Jun 4, 2005 | 11:12 AM
Hybrid96EK's Avatar
Can anyone confirm this?</TD></TR></TABLE>
Go switch them and "confirm" it yourself.
Old Jun 4, 2005 | 11:28 AM
WildPig's Avatar
Default Re: Having o2 sensor problems...........again........... (Hybrid93Eg)
Thanks for your "help."
Old Jun 4, 2005 | 12:04 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WildPig &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for your "help." </TD></TR></TABLE>
Everyone wants everything spoon fed to them around here. Take a gamble, go try different a different configuration. Whats the worst thing you will do? Wire it up incorrectly? Again?
b18cEF9
13
May 8, 2005 04:45 PM
eastbay92cx
Aug 30, 2004 06:51 AM
elmalouno
11
Aug 18, 2004 09:06 AM
xmd
Oct 12, 2003 10:38 AM
