What "kind" og bolts for diy camber
Old Jun 3, 2005 | 01:50 PM
BLUE EH3's Avatar
Help we my pennies
Default What "kind" og bolts for diy camber
can you use any bolts? im scared that the bolt mite snap..
http://home.earthlink.net/~civ....html
Old Jun 3, 2005 | 02:02 PM
r6samson's Avatar
I think I used stock bolts. Depends how much you shim it out. You don't want to strip, break off, be too long of a bolt and not lock, be to short of a bolt and not lock, to weak of a bolt and break, wrong threads. Just watch those little things.
JP
Old Jun 3, 2005 | 02:11 PM
solareclipseauto's Avatar
Default Re: What "kind" og bolts for diy camber (BLUE EH3)
yeah it depends how much your goin to shim it out. if you need to shim it out alot get a longer bolt but make sure it has the same thread as the old bolt and also make sure not to torque it down to hard or else you will snap the bolt.
Old Jun 3, 2005 | 02:48 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: What "kind" og bolts for diy camber (solareclipseauto)
i wanted to about the strenght of the bolt!
Old Jun 4, 2005 | 10:50 PM
BLUE EH3's Avatar
Help we my pennies
i found 2 OEM bolts work perfect! now i need 2 MORE
Old Jun 4, 2005 | 11:00 PM
Tim.'s Avatar
i used my OEM bolts when i did this. i think i used 2 washers. maybe 3. so far i have had no problems, it has been about 6 months. is this safe to do? or am i in for it eventually?
Old Jun 4, 2005 | 11:01 PM
handa's Avatar
Default Re: What "kind" og bolts for diy camber (spoon0313)
very smart!
Old Jun 5, 2005 | 02:17 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: What "kind" og bolts for diy camber (handa)
now , iwish i knew what those bolts are used for!!! so i can order more
Old Jun 5, 2005 | 02:57 PM
sohcvtec1995's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by handa &raquo;</TD></TR><TR><TD CLASS="quote">
very smart! </TD></TR></TABLE>
is that way accurate? I need new tie rods, befor i can get an alignment, but i am super broke. and my rear camber got a bit nasty when i did my rear disc con version. (sorry to kinda thread jack)
Old Jun 5, 2005 | 03:03 PM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
I don't know why some of you guys think you want 0 degrees of camber all the way around.
Unless you're dumped in the weeds, you'll have no more than 1-1.5 degrees which is perfectly acceptable and won't produce weird tire wear if your toe is set to 0 or close to it.
Or... hell, do it the right way and buy the $100 camber adjuster. Yeesh.
Old Jun 6, 2005 | 08:28 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: What "kind" og bolts for diy camber (SkyeC)
i dont see the point on gettin an alignment till i get fix my camber on all 4 wheels or at least the back
Old Jun 6, 2005 | 08:33 AM
syked's Avatar
Dont drive on it much, i waited for all 4 of mine, and both my 2 front tires wore out like no other. the toe was way off, so BE CAREFUL! i had brand new tires too, now they got bout 50% left, in like 1 week
Old Jun 6, 2005 | 09:08 AM
BLUE EH3's Avatar
Help we my pennies
Default Re: (syked)
50% in a week!!!!! i drove to from NJ-Md and back!! and my tire have a little wear!! i read about people who drop their cars and never a camber issue!! how??
what is toe and what is camber?
Old Jun 6, 2005 | 02:04 PM
BLUE EH3's Avatar
Help we my pennies
Default Re: (BLUE EH3)
bumpy
danielblushtein
Mar 9, 2011 05:28 PM
benitom
Suspension & Brakes
16
Oct 14, 2008 04:46 AM
bdubnyc
13
May 13, 2008 10:16 AM
KFMRC
Honda S2000
May 18, 2006 11:08 AM
Matgallis
Aug 25, 2004 02:36 PM
