Electronically Increasing Miles On Odometer
Old Jun 3, 2005 | 12:39 PM
litterbox's Avatar
I am a (Trial User) Army
Default Electronically Increasing Miles On Odometer
Hey,
Last year I remember finding a thread about how to electronically roll back your odometer. I searched for an hour and can't find it. Anyone know what I'm talking about?
I've got a GSR cluster in my EG with 60,000miles on it. My car has 255,000miles on it. I've got VA inspection this weekend and need to roll forward my new cluster to make it pass. I don't want to just use a sharp pointed piece and push the numbers up.
Thanks.
Old Jun 3, 2005 | 12:43 PM
civiccpedx's Avatar
Default Re: Electronically Increasing Miles On Odometer (litterbox)
i always though if you take out the cluster, you can just hook it up to a screwdriver, at least that is what i have heard.
Old Jun 3, 2005 | 12:44 PM
litterbox's Avatar
Default Re: Electronically Increasing Miles On Odometer (civiccpedx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccpedx &raquo;</TD></TR><TR><TD CLASS="quote">i always though if you take out the cluster, you can just hook it up to a screwdriver, at least that is what i have heard.</TD></TR></TABLE>What do you mean?
Old Jun 3, 2005 | 12:49 PM
civiccpedx's Avatar
im not exactly sure, but i desticntly remember hearing that you can just hook up a drill to your odometer, and depending on the direction it will increase or decrease, sorry i can't be much more help, but that is all i know....
can't you remove all the numbers from the cluster and just set them to the desired mileage?
Old Jun 3, 2005 | 12:52 PM
cxSHOE's Avatar
hey bud..
just take out your speedo. unsnap the odometer thingy from the gauge itself., look at your drill, and it will all come together on how to do it..... its not that hard...then just snap the odometer thingy back in ..
Old Jun 3, 2005 | 12:54 PM
litterbox's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civiccpedx &raquo;</TD></TR><TR><TD CLASS="quote">im not exactly sure, but i desticntly remember hearing that you can just hook up a drill to your odometer, and depending on the direction it will increase or decrease, sorry i can't be much more help, but that is all i know....</TD></TR></TABLE>I'll check that out when I pull the cluster tonight.
can't you remove all the numbers from the cluster and just set them to the desired mileage?</TD></TR></TABLE>I think the way you do that is by pushing them with a sharp object. But I'm worried about breaking the little gear mechanism.
Thanks for your help.
Old Jun 3, 2005 | 12:56 PM
civiccpedx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE &raquo;</TD></TR><TR><TD CLASS="quote">hey bud..
do what he says
Old Jun 3, 2005 | 01:02 PM
cxSHOE's Avatar
hey litterbox,
i delete that last post... you dont really need to remove the needle as that thread said.. so heres what i did,
with the speedo mph cover still on. (do not remove the needle) just locate the odometer miles and unsnap it as in this photo. and then take it out.. the numbers can now be freely moved around. then snap it back in.
if you are doing an eg. the numbers will not move around freely and you will need to use a drill. counter in hand drill in the other you get what i mean.. its simple.
remember no need to remove the speedo needle, or cover. just snap the counter off and snap it back in when done....
Old Jun 3, 2005 | 01:09 PM
litterbox's Avatar
Default Re: Electronically Increasing Miles On Odometer (cxSHOE)
Again Jackie, you're the man.
I'll let you all know how it goes.
Old Jun 3, 2005 | 01:14 PM
cxSHOE's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">Again Jackie, you're the man.
I'll let you all know how it goes.</TD></TR></TABLE>
yea read my last post i had to update it several times bud... changing the integra the numbers are loose as you snap it off.
and if doing this on an eg's gauge the numbers stay together and the drill is needed to move the numbers...
both are easy eitherway..
Old Jun 3, 2005 | 07:00 PM
TurboR1391's Avatar
Wow you guys are definitely generation X. Modern day criminals.
Old Jun 3, 2005 | 09:05 PM
nocturnaldragon's Avatar
I wouldent do it that way, Ive done it on two clusters now and the clip that holds that pin in breaks everytime.
Old Jun 3, 2005 | 09:28 PM
lazie's Avatar
http://www.courtlukens.com/Tec...r.htm
Old Jun 3, 2005 | 10:23 PM
AGENT 99's Avatar
Default Re: (lazie)
Shitbox, your going to hell for this! Yeah right, increasing...uh huh!
j/k man. Hey, wtf I am doing here? Back to GDD!
(its elmo!)
Old Jun 3, 2005 | 11:37 PM
FlatBrokeHatch's Avatar
Default Re: (EINSTEIN)
Sneaky bastages
Old Jun 3, 2005 | 11:42 PM
Frozen E's Avatar
H-T White Ops
Default Re: Electronically Increasing Miles On Odometer (BronzeEG)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BronzeEG &raquo;</TD></TR><TR><TD CLASS="quote">Wow you guys are definitely generation X. Modern day criminals. </TD></TR></TABLE>
He's adding miles to his odometer, not taking away.
Old Jun 4, 2005 | 01:06 AM
Hurricane's Avatar
Default Re: Electronically Increasing Miles On Odometer (IslandSi)
In my state you dont have to record the miles on the Title after 100k, hmmm, can anybody say resell value increase ?
BTW, I'm just joking.
Old Jun 4, 2005 | 07:37 AM
litterbox's Avatar
Default Re: Electronically Increasing Miles On Odometer (Hurricane)
You cynics, I'm increasing the miles to match my motor. But I found out that they don't record the mileage at VA state safety inspection. Only at emissions inspection, which I have another year before I have to take.
Old Jun 4, 2005 | 08:20 AM
e jay one's Avatar
good to know
Old Jun 4, 2005 | 09:09 AM
Crasian's Avatar
wow, thats a useful link
Old Jun 10, 2005 | 04:22 PM
Milano_EH3's Avatar
Default Re: (FarOutCoupe)
Holy ****...someone actually passed out that link from my site. And I thought that was the bastard, useless child of my tech articles (not like any of them are really that good).
Old Jun 10, 2005 | 04:38 PM
Setsuna F Seiei's Avatar
Honda-Tech Platinum Member
Default Re: (Milano_EH3)
good shiet son, I saved it to my favorites
Old Jun 10, 2005 | 04:49 PM
B16aDasher's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">Hey,
Thanks.</TD></TR></TABLE>
just stick the stocker in for the inspection
BiggieBert
Jul 29, 2008 04:05 PM
xdjoynerx
Apr 4, 2004 01:23 AM
xdjoynerx
Mar 6, 2004 10:46 PM
BlueIntegraBoy
Jan 20, 2004 10:52 AM
is3oo
Jul 18, 2003 06:30 PM
