car wont start need help asap please
well my car wont start today almost nothing turns on . battery is good ecu is good. headlights and tails work so does the hazard lights but not the turn signals . power door locks work but not the windows.interior lights dont work ,climate controls dont work mirros dont work either . none of the instruments on the gauge cluster work i checked all those bulbs but when i do turn on the headlights it lights up . i swapped the cluster with another one and that didtn work on my car but does on my sisters .the e brake light doesnt turn on neither does the srs or any of the lighst that usually turn on when starting the car . it doesnt crank over but the fuel pump does work . i dunno heres a link to what ive been doing to my car maybe something that i took off is causing this to happen.http://www.clubcivic.com/board...58036
it doesnt turn over or make any kind of sound at all . i know the battery works because my sister has the same car and i switched batteries ,ecu's and ghauges clusters and everything works on hers and not mine
one thing i can say that i know the alternator has been bad on mine for like 2 months but its hardly been driving since so could that be the problem although im guesing no because the battery should power it to start rite?
i also removed my alarm 3 days ago because it was all busted but i did start the car after removing it . and besides the ignition wires the rest of the wires were t taped in
did a lil research here on ht and somebody with the same problem had a bad clucth sensor maybe thats whats wrong with mine ill check tomorow oh yeah tried to jump start it too that did notin too
yup it was the fuse had to go to like 3 different stores to find the damn thing. thanx guys but i feel dumb because the fuses were the first thing i checked and i missed it
check and listen if your fuel pump is priming up or not. if not then check the fuse, its a 15a fuse, under the name altenator valve, but in along those words. i had the same problem, but when i swapped clusters, but that was my problem
B serious
Mar 4, 2011 10:04 AM
sublimnal
Oct 12, 2007 07:09 PM
seeker2921
12
Jul 22, 2006 11:36 AM
