vss causing vtec not to engage?
Old Jun 2, 2005 | 10:09 AM
LudeJdm's Avatar
Default vss causing vtec not to engage?
hey everyone i have a question about the vss...if im getting a vss code would this cause vtec not to engage? also would a bad cluster or bad speedometer cable cause a vss? if so how can i tell which one is the one thats causing the code?
i have a d16z6 in my ef and my speedometer doesnt work...and im getting code 17 vehicle speed sensor...i dont know if i have a bad sensor or bad speedometer cable or bad cluster....i dont know which one to replace...can ne one help me???????thanks in advance
Old Jun 2, 2005 | 12:40 PM
PURPLETERROR aka BIGMATT's Avatar
Default Re: vss causing vtec not to engage? (lbautista23)
what ecu are you running? and are you using the cable vss, or electronic?
Old Jun 2, 2005 | 05:30 PM
LudeJdm's Avatar
Default Re: vss causing vtec not to engage? (PURPLETERROR)
i have chipped p28 and im using cable
Old Jun 3, 2005 | 09:51 PM
LudeJdm's Avatar
how can i tell which one is the problem? i know its either 1 of these 3 things....speed sensor, speed cable, or the cluster itself...is there a way to test out the 3 things to find out which isnt workn????
Old Jun 3, 2005 | 10:35 PM
TurboLSVtecTeg's Avatar
Replace the speedo cable and you will be set. Its like 30 bucks or so from the dealer I think.
Old Jun 4, 2005 | 10:05 AM
jmcclell's Avatar
Yes, a faulty VSS sensor will stop the VTEC from engaging.
Your honda has to go faster than 30 Km/h before the ECU will allow the VTEC to engage. The ECU also reduces the RPM cutoff to around 6000RPM below this speed.
boyee1
10
Dec 15, 2007 10:07 AM
EF9 JAMS!!!
Dec 10, 2006 10:26 AM
LudeJdm
Oct 8, 2006 03:02 PM
LudeJdm
Jun 2, 2005 10:21 AM
csp88crx
Jul 11, 2002 08:07 PM
