vss not engaging vtec?
hey everyone i have a question about the vss...if im getting a vss code would this cause vtec not to engage? also would a bad cluster or bad speedometer cable cause a vss? if so how can i tell which one is the one thats causing the code?
i have a d16z6 in my ef and my speedometer doesnt work...and im getting code 17 vehicle speed sensor...i dont know if i have a bad sensor or bad speedometer cable or bad cluster....i dont know which one to replace...can ne one help me???????thanks in advance
Re: vss not engaging vtec? (lbautista23)
Check your connections. Make sure everything is hooked up and then try replaceing your sensor with a buddies.
aragorn1023
08-12-2007 11:11 PM
DA_JDM
14
05-30-2007 08:40 AM
