Pinging after timing belt install 97 Civic
Old Jun 2, 2005 | 10:00 AM
Truck 1's Avatar
Default Pinging after timing belt install 97 Civic
I just installed a new timing belt on my 97 civic. It now pings under a load. I set the ignition timing to 12 btdc but it still pings. Does it sound like the belt is one tooth off? Does any one have a good description of where the marks are supposed to line up? Thanks for the help!
Modified by Truck 1 at 2:57 PM 6/2/2005
Old Jun 2, 2005 | 11:18 AM
IHateJDM's Avatar
Default Re: Pinging after timing belt install 97 Civic (Truck 1)
What motor? 12 btc doesn't sound right. Do you have a timing light?
Old Jun 2, 2005 | 12:47 PM
snatch's Avatar
Default Re: Pinging after timing belt install 97 Civic (IHateJDM)
Try setting it at 16 BTDC, I think that's stock spec. There are 3 marks when you're setting the timing on the crank pulley. All 3 are really close together, I think the middle on is white, and the outer ones are red. One is for 14 BTDC, then 16 BTDC, and 18 BTDC. Try checking that and adjusting it.
Old Jun 2, 2005 | 02:04 PM
Truck 1's Avatar
I just rechecked the emission sticker. It says to set the timing at 12 BTDC + or -2 degrees. It is a 1.6L 97 civic. I'm not sure of the family code. The timing light says its dead nuts on at 12 degrees with the blue connector jumped. thanks again!
the_dxB16
18
Jan 11, 2019 08:00 AM
wcpreston
Nov 29, 2016 10:32 PM
THE-SHIZZLE
Jun 1, 2010 08:42 AM
vi3tzkidd
Feb 9, 2010 04:00 PM
NatedoggAZ
14
Apr 13, 2005 09:51 AM
