HELP ASAP! Cant remove stud! Calling all non vtec d-series guru's
Okay i was stupid and over tightened a valve cover nut and snapped the stud. Its not a probelm gettting the bolt loose...the problem is i cant get the bolt OUT. I loosend(sp?) the bolt and it moves up and down freely but it wont slide/pull out of the hole in the cam bearing cap. I am lost for ideas how to get it out, is there any type of retaining washer, dowel, or spring holding it in from being pulled out. I dont have to remove the whole rocker arm assembly i hope. Oh yea this is on a D15B7 motor, its the stud by the oil cap. Please help me this is the only thing stopping me from completing my project. THANKS!
Re: HELP ASAP! Cant remove stud! Calling all non vtec d-series guru's (92CHB)
So its completely loose? Maybe loosen it some more with a bit of pressure upward (like taking it out). Take a look at a new stud and reverse engineer it.
You have to loosen all bolts for the rocker arm assembly according to the sequence listed in a helms or chilton's manual. Otherwise, you may warp part of the rocker arm assembly. The same can be said about tightening them. Make sure you have a torque wrench. Good luck.
