In order to run 30 PSI on a turbo car......
you can build a motor to handle 60psi but it will never last with gas thats for sure. You can go with nitromethane setup like bob norwood built but thats all custom ofcourse. Alcohol can around 40-50psi easily.
b18c block would need sleeves pistons rods head with good valve springs and retainers. And run alcohol. you can run 50 psi easily.
Aren't stock cranks on Hondas forged? If so it can probably hold that much boost.. not sure for how long though. But on a drag car, those parts are replaced constantly.
Yes, the stock crank will hold it. Keep in mind it only has to sustain that pressure for (not even)7-8 seconds of actual pressure time. It took me longer to write this post typing 70wpm
what needs to be done to a b18c1 block for it to be able to handle 60psi?
tegman23
Apr 10, 2007 05:13 PM
TurboB18C1
Jul 7, 2004 02:27 PM
good luck
