Reccomend a Good Oil Cooler for Turbo
Old Feb 8, 2002 | 01:14 AM
Snafu-Si's Avatar
From: 99th level of hell, where all roads only go straight, where curves go to die. Houston Texas
Default Reccomend a Good Oil Cooler for Turbo
I want to get one when I get a turbo. I hear they really help the oil temp a lot and that means alot when you have a turbo.
Anyway, does anybdoy have any expericence with some. If so, which one? I'm thinking about get the Greddy Oil Cooler kit, it's seems to be pretty nice.
Suggestions?
Old Feb 8, 2002 | 01:25 AM
austrian type-R's Avatar
Default Re: Reccomend a Good Oil Cooler for Turbo (Snafu-Si)
Before you hook an oilcooler up, you should first measure with an gauge how high the oil temp realy is. It is not good to have a too cold oil.
Get a coolder water thermostat for 160 Degs. Than look at your oil temp. It should be about the same. When it is 190+ degrees, I would install a oilcooler (have heard Greddy is a good one) with a thermostat to allow the oil a quick warm up.
[Modified by austrian type-R, 11:26 AM 2/8/2002]
Old Feb 8, 2002 | 01:45 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Reccomend a Good Oil Cooler for Turbo (austrian type-R)
IMO, I would look into making your own.
art
Old Feb 8, 2002 | 08:46 PM
Snafu-Si's Avatar
Default Re: Reccomend a Good Oil Cooler for Turbo (Arturbo)
I just heard that it is better safe than sorry that's why I was considering getting a oil cooler. Understandably that it wouldn't be so good to run cool oil but, I have never heard or that problem before with a turbo, always the too hot problem. I own a 99 Civic Si, does that help you. Cuase... I mean... hell, I dunno
Thanks for the help
Anymore suggestions are welcome
Old Feb 9, 2002 | 08:14 AM
SiR-G96's Avatar
I'll look into making one yourself too. Perma-cool makes good and cheap coolers, you can find them in Summit and Jegs. Never buy B&M coolers. I'll suggest using a thermostate if it's below freezing in winter!
Old Feb 10, 2002 | 12:24 AM
Snafu-Si's Avatar
Default Re: Reccomend a Good Oil Cooler for Turbo (SiR-G96)
How do I "make" my own?
Old Feb 10, 2002 | 01:08 AM
MugenSi00's Avatar
why no B&M? I have a friend that has been using one for 16 months with no problems at all. All of them are about the same with the only major differences being in core size. Greddy seems to be the best, but also the most expensive ~$600
Old Feb 10, 2002 | 01:12 AM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Reccomend a Good Oil Cooler for Turbo (MugenSi00)
The thing I dont like about the B&M is you have to relocate the oil filter. It wont cause any problems, I just dont like it there. What you need it the sandwitch adapter that fits inbetween the block and oil filter. Then you need a oil cooler core, stainless steel lines, and Earls fittings. Can be done for a little over a $100.
art
Old Feb 10, 2002 | 08:12 AM
b18bturbo's Avatar
HERE Is a good article for the DIY on oil cooling....
http://hybrid.honda-perf.org/tech/oilcooler/index.html
Old Feb 10, 2002 | 08:35 AM
Snafu-Si's Avatar
Default Re: Reccomend a Good Oil Cooler for Turbo (b18bturbo)
Man, it sounds so complecated, I have no idea where to start or what to do.. So far.... I'm leaning towards the Greddy kit. Anything wrong with the Greddy kit's???
Old Feb 10, 2002 | 09:24 AM
2000_Civic_Si's Avatar
The greddy oil cooler is the best, I have seen. It comes with stainless steel lines and a nice cooler, IMO it is a great setup. I would also recommend checking the oil temp before you install the oil cooler. You dont want to oil to be too cold! Hope this helped.
Old Feb 10, 2002 | 09:32 AM
Snafu-Si's Avatar
Default Re: Reccomend a Good Oil Cooler for Turbo (2000_Civic_Si)
How do I check the oil temperature?
Old Feb 10, 2002 | 09:43 AM
falcongsr's Avatar
What is this crap?
its called an oil temperature gauge.
g-gameslude18
Sep 15, 2010 12:50 PM
Cee_mon
Nov 18, 2005 06:11 AM
BlowOff
Jun 28, 2001 08:33 AM
