rubbing issues with new suspension!
Old Jun 1, 2005 | 11:17 AM
handa's Avatar
Default rubbing issues with new suspension!
Setup:
-1993 Civic EX 4dr w/ B-series swap
-KYB AGX + H&R Sports
-15" SE GSR wheels (195/55/15)
Recently just installed my new suspension. I've set the KYB's at stiffest notch. My front would rub every corner...and these are SPORTS h&r's!!
it's about a finger gap or smaller.
any ideas? what if i have H&R Race? wouldn't that be lower? do i need stiffer springs? any ideas?
Old Jun 1, 2005 | 11:23 AM
Deemeetree's Avatar
Electrician
Wow, I was at flush up front and I never rubbed for some reason. What size tires are you running?
Old Jun 1, 2005 | 11:26 AM
_Spugen_'s Avatar
Take off the plastic.
Old Jun 1, 2005 | 11:30 AM
handa's Avatar
Default Re: (Dimitri_EG8 a.k.a. Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimitri_EG8 a.k.a. Dimi &raquo;</TD></TR><TR><TD CLASS="quote">Wow, I was at flush up front and I never rubbed for some reason. What size tires are you running?</TD></TR></TABLE>
195/55/15
Old Jun 1, 2005 | 11:31 AM
Deemeetree's Avatar
Electrician
Default Re: (_Spugen_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Spugen_ &raquo;</TD></TR><TR><TD CLASS="quote">Take off the plastic.</TD></TR></TABLE>
Algerian Engineer.
Old Jun 1, 2005 | 11:34 AM
handa's Avatar
i believe i would rub the fenders hard if i take corners in autox.
perhaps these h&r's are too soft. i may need stiffer springs. any recommendations? spring rates?
Old Jun 1, 2005 | 11:41 AM
hondahybrids's Avatar
Default Re: (handa)
U need stiffer springs,you should not rub with a 15" wheel.I had/have that same gap and i don't rub.
BTW,What is your wheel offset?
Old Jun 1, 2005 | 11:45 AM
handa's Avatar
Default Re: (HondaCity)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCity &raquo;</TD></TR><TR><TD CLASS="quote">
BTW,What is your wheel offset?</TD></TR></TABLE>
i'm quite not sure. any way i can find out?
Old Jun 1, 2005 | 11:49 AM
dohcdelsol's Avatar
Default Re: (handa)
I have the same problem...
h&r's on koni's with 99-00 si wheels... 195-55-15
what color are your h&r's? If they are black then you have the sport, if they are red, you have the race.
Old Jun 1, 2005 | 11:53 AM
handa's Avatar
Default Re: (dohcdelsol)
they are black.
Old Jun 1, 2005 | 12:00 PM
EgRedSi's Avatar
Default Re: rubbing issues with new suspension! (handa)
You have too much tire.
Old Jun 1, 2005 | 12:03 PM
pancake56's Avatar
i have the same setup on the same car. BUT, my tires are 195-50s, NOT 55s. You have a larger sidewall than I do. And also, did you forget the rubber stopper?
GetawayInMoscow's Avatar
Default Re: rubbing issues with new suspension! (EgRedSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EgRedSi &raquo;</TD></TR><TR><TD CLASS="quote">You have too much tire.
w3rd....
You should be running 195/50/15
Old Jun 1, 2005 | 12:06 PM
EgRedSi's Avatar
Default Re: rubbing issues with new suspension! (GetawayInMoscow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow &raquo;</TD></TR><TR><TD CLASS="quote">
You should be running 195/50/15</TD></TR></TABLE>
No issues here, my Teins are opened to the last thread.
195/50/15
Old Jun 1, 2005 | 12:07 PM
handa's Avatar
mmm i see. time for new tires anyway. thanks all for the help!
xl cubert lx
Jun 19, 2007 02:45 PM
aZnAcCoRd02
Feb 22, 2007 10:14 AM
hotsuma23
Mar 25, 2005 11:41 AM
TypeR1558
Jul 31, 2002 12:13 AM
99civic_exSB
19
Jul 10, 2002 08:23 AM
