rubbing issues with new suspension!
Setup:
-1993 Civic EX 4dr w/ B-series swap
-KYB AGX + H&R Sports
-15" SE GSR wheels (195/55/15)
Recently just installed my new suspension. I've set the KYB's at stiffest notch. My front would rub every corner...and these are SPORTS h&r's!!
it's about a finger gap or smaller.
any ideas? what if i have H&R Race? wouldn't that be lower? do i need stiffer springs? any ideas?
Re: (Dimitri_EG8 a.k.a. Dimi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dimitri_EG8 a.k.a. Dimi »</TD></TR><TR><TD CLASS="quote">Wow, I was at flush up front and I never rubbed for some reason. What size tires are you running?</TD></TR></TABLE>
195/55/15
195/55/15
Electrician
Re: (_Spugen_)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by _Spugen_ »</TD></TR><TR><TD CLASS="quote">Take off the plastic.</TD></TR></TABLE>
Algerian Engineer.
Algerian Engineer.
Re: (_Spugen_)
i believe i would rub the fenders hard if i take corners in autox.
perhaps these h&r's are too soft. i may need stiffer springs. any recommendations? spring rates?
Re: (HondaCity)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HondaCity »</TD></TR><TR><TD CLASS="quote">
BTW,What is your wheel offset?</TD></TR></TABLE>
i'm quite not sure. any way i can find out?
Re: (handa)
I have the same problem...
h&r's on koni's with 99-00 si wheels... 195-55-15
what color are your h&r's? If they are black then you have the sport, if they are red, you have the race.
Re: rubbing issues with new suspension! (handa)
i have the same setup on the same car. BUT, my tires are 195-50s, NOT 55s. You have a larger sidewall than I do. And also, did you forget the rubber stopper?
Re: rubbing issues with new suspension! (EgRedSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EgRedSi »</TD></TR><TR><TD CLASS="quote">You have too much tire.
w3rd....
You should be running 195/50/15
w3rd....
Re: rubbing issues with new suspension! (GetawayInMoscow)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GetawayInMoscow »</TD></TR><TR><TD CLASS="quote">
You should be running 195/50/15</TD></TR></TABLE>
No issues here, my Teins are opened to the last thread.
195/50/15
195/50/15
