cutting valve cover
Old May 31, 2005 | 10:53 PM
Suck my DX's Avatar
Default cutting valve cover
when i cut the valve cover on my b16 for cam gears....is there any chance that the beltmight come off the gears....or should i try to cut it so that i can still adjust the cam gears but its not cut all the way to the top??
Old Jun 1, 2005 | 03:44 AM
NJIN BUILDR's Avatar
Default Re: cutting valve cover (AMPYR_one)
The cover does not help keep the belt on.It only keeps junk out of the gears/belt.
Glenn
Old Jun 1, 2005 | 01:05 PM
per4mance's Avatar
Default Re: cutting valve cover (NJIN BUILDR)
if the belt moves off then it would rub on the valve cover and eventually break it, or wear it down real bad.And if it actually did move of the tooth that also means that its out of alighnment so then you would check the tensioner and see why.So no it will not come off just by cutting the valve cover.
Old Jun 1, 2005 | 01:08 PM
Suck my DX's Avatar
Default Re: cutting valve cover (per4mance)
makes sense...thanks guys
Old Jun 1, 2005 | 03:12 PM
90REDHATCH's Avatar
I am a scammer!
what i would do is cut big circles with a hole saw just enough to adjust them because I cut the whole side off once and a rock took a big gash out of the timing belt and damaged the water pump pulley that s just my advice
Old Jun 1, 2005 | 05:28 PM
Suck my DX's Avatar
Default Re: cutting valve cover (PhoShizzle-Tech)
yeah thats kinda what im scared of...now i know that it is unlikely that a foreign object will enter my motor bay...but there is always that chance...like u said im gonna cut it only as far as i have to...i think that way it will lessen the chance of something gettting caught up in there
Old Jun 5, 2005 | 02:15 PM
90REDHATCH's Avatar
I am a scammer!
Yeah bro just use a hole saw and us the size that you can see adjusting srews on the cam gear just take your time and patient with it and it will come out nice Trust ME
Old Jun 5, 2005 | 06:46 PM
Suck my DX's Avatar
well i bought a cut valve cover for 20 bux...so im gonna just use that to tune it and put the other one back on when its done...
Old Jun 6, 2005 | 07:19 PM
90REDHATCH's Avatar
I am a scammer!
Default Re: cutting valve cover (Suck my DX)
good decision that works also
Joey Mitchell
Jul 11, 2018 02:53 AM
2k.civic.si
Apr 29, 2012 07:42 AM
rice h8r
Jul 15, 2011 09:32 PM
jaje
Nov 11, 2009 10:22 AM
B16b-EJ8
Apr 29, 2007 12:12 PM
