Tach and speedo not working!
Old May 31, 2005 | 08:51 PM
NobodysHero's Avatar
Default Tach and speedo not working!
I finished my H23->h22 swap, and now my speedo and tach don't work and i cant figure out why. I swapped the ECU to a JDM P13, I used the stock harness and wired my own VTEC. I checked my VSS and everythings connected. Can someone please help me. thanks.
Old May 31, 2005 | 11:00 PM
Altilude's Avatar
Default Re: Tach and speedo not working! (NobodysHero)
i'd check fuse 23 and 13 in the underdash fuse panel for the speedo...
the taco looks different tho, and the helms is a lil erroneous (page 23-126/127) it possibly gets it's power thru the ICM (ignition control module in dizzy) but there is a wire i can't trace between the two pages, it leads off the page, but unlike the others it doesn't connect to anything on the next page. (?)
it is odd that both are out - since they appear individually controlled... hmm
best of luck.
Old Jun 1, 2005 | 07:20 PM
checked fuses none of them were blown, but im still having problems.
Old Jun 1, 2005 | 07:41 PM
Siegfried's Avatar
Default Re: (NobodysHero)
Check your VSS & the wires that goes to the VSS.
Old Jun 1, 2005 | 08:37 PM
Already checked those wires, everything is connected fine
Old Jun 2, 2005 | 01:03 AM
Siegfried's Avatar
When I said check it was with a multimeter, and if you' re sure that the wires are good, maybe your VSS is dead. Try to check if you got an error code.
Old Jun 2, 2005 | 08:03 PM
Altilude's Avatar
Default Re: (Siegfried)
bump for curious if it was solved and how.
Old Jun 3, 2005 | 01:09 PM
nope, still not solved
rak511
Jun 21, 2013 09:06 PM
atownludeh22a
Jan 11, 2009 01:32 PM
Eklsv-t
Sep 24, 2008 02:32 PM
crxsi541
Jan 10, 2005 11:13 AM
b20_ed
Mar 6, 2004 07:49 PM
